RS6 Turbos - Max Boost
Hi Guys,
Just wondering if anyone can tell me the max boost that they have found they can run with a pair of RS6 turbos (not hybrids) while maintaining efficency?
TIA
RS-MAD
TIA
RS-MAD
RE: RS6 Turbos - Max Boost
You should ask max mass airflow, because basically the boost doesn't mean anything. Then you can compare boost if the engine is totally same, and also the hot side of the turbo. Because the pressure comes from restriction, if the engine flows freely, you can't get boost at all, but the air mass is big.
Okkim - Thanks do you now the max mass airflow the turbos are good for?
No, sorry. You have to read the RS6 compressor map and calculate.
From the RS6 turbo: K04-29 map whilst keeping the efficiency >70% or better
max pressure ratio: 2.7 @ 0.155 m3/s airflow by volume @ max shaft speed 167,000 rpm
ie max boost 25 psi
max flow rate: 0.175 m3/s airflow by volume @ pressure ratio 2.21 @ shaft speed 156,000 rpm
ie around 200 g/s (or 400 g/s for two , or even 510 bhp)
If you forget about the efficiency, run the compressors off the map, and deal with the heat, on my S4 heads / intake / exhaust combo the RS6 turbos could make 613.93 bhp assuming VE of my combo doesn't change from current (in reality it would).
It's all numbers and theory, and I could have got it wrong on my scrap of paper!. You're probably better off fitting them and measuring EGT, exhaust manifold pressure and intake temp. Stop when one of these gets too high.
ie max boost 25 psi
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
I got 480 on the maf from memory!
Low egts,intakes and healthy timing. No water injection.
The turbos will go more but may not last or be as efficient.
Car did 518 bhp@TW with 1.9 P to 1.5 RL in 3rd.
Loving it, shreds rear tires in 3k too.
Re: RE: RS6 Turbos - Max Boost
What car do you have? 518hp is that Flywheel or Wheels?flashyg wrote:I got 480 on the maf from memory!
'TW' = The Wheels.rs-mad wrote:What car do you have? 518hp is that Flywheel or Wheels?flashyg wrote:I got 480 on the maf from memory!
Mike
Q7
Q7
RE: Re: RE: RS6 Turbos - Max Boost
Dyno setting on shoot6F AND done in 3rd gear. Anyone would think you're trying to cheat the numbers G
Nice MAf reading
Nice MAf reading
Re: RE: Re: RE: RS6 Turbos - Max Boost
Hutch wrote:Dyno setting on shoot6F AND done in 3rd gear. Anyone would think you're trying to cheat the numbers G![]()
Nice MAf reading
But I'm not .You cheeky little minx. We all know shoot 44 gives bigger FW figures. I don't need em.
In fourth Ill have more Poower!
Who's got a big wheel power then
Watch out a k16 car could be along any minute to get me, never the biggest fish...Satins child, Andy even, Stevey.DDave the list goes on.
Good luck to all.
G
quattronutter
I can see a head to head with "hutch & flashyg " at rs246 live ..
Unit 20
0151 3366888
0151 3366888
