Clutch renewal
klauster
Re: Clutch renewal
Post by klauster » Thu Dec 20, 2012 12:59 pm
sutts wrote:
klauster wrote:When I had mine done at 86k I had the whole thing done, clutch, flywheel and return pipe.... I went OEM
At the stealers, or an Indie?
Stealers, £1600 the lot inc fitting :)
D8vil
Re: Clutch renewal
Post by D8vil » Sun Dec 23, 2012 10:16 pm
Indie (autotechnica) is
£100 clutch only
£1800 clutch and flywheel
I'm thinking either Sachs or loba now I think
grizz
Re: Clutch renewal
Post by grizz » Thu Dec 27, 2012 8:43 pm
A new genuine clutch is about £230 + vat .....
Unit 20
0151 3366888
supersi
Re: Clutch renewal
Post by supersi » Thu Dec 27, 2012 9:37 pm
TimDogg wrote:Grizz - some guys get the Sachs - do you recommend that over the Loba?
We use a higher grade of billet material for our single mass flywheel vs Sachs flywheel, ours has a higher coefficient of friction and is harder wearing , and lighter.
We can also supply the Sachs kit, id say at a unbeatable price too, i will add to LOBA website/shop in the new year, we don't actively push as feel ours is a better option.
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
supersi
Re: Clutch renewal
Post by supersi » Sat Jan 12, 2013 1:47 pm
I have now added SACHS own two options too our webshop
http://www.loba-motorsport.com/shop/aud ... s-quattro/
Coaster
Re: Clutch renewal
Post by Coaster » Wed Jan 16, 2013 2:32 pm
I had a very occaisional slow returning clutch although no feeling through the pedal, mentioned it to the Dealer and they replaced the clutch return pipe FOC. However, if anything this has made the problem worse and my car now has an occaisional sticking pedal which is a horrible feeling when driving the car. From this experience I would not assume that doing the CRP alone would cure a sticking pedal.
spikeyboy101
Re: Clutch renewal
Post by spikeyboy101 » Wed Jan 16, 2013 7:03 pm
TBH i think most people have stated that changing the CRT hasnt made any difference to a sticking pedal - but if you got it done FOC then no harm done.
Only thing that fixed mine was a new Dual Mass Flywheel and Clutch - my fly wheel had given up the ghost big time, clutch was only 60% worn, Garage had a nightmare getting the flywheel and sprocket out is was than nackered.
Mine was sticking every sprinted drive, and was very slow to return with normal driving.
Other than than i think its the clutch return bearing that causes the sticking clutch.
vestax32
Clutch renewal
Post by vestax32 » Fri Jan 18, 2013 10:08 am
New clutch, that's the bottom line.
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
Tile Diver
Re: Clutch renewal
Post by Tile Diver » Fri Jan 18, 2013 10:36 am
vestax32 wrote:New clutch, that's the bottom line.
+1
I wasn't having any issues with regards to the return of the clutch pedal, but did find it virtually impossible to get the car into first or reverse. So to the stealers it was, I instructed them to check the less expensive potential causes first, bleed the clutch, return pipe stuff like that, no issues were found with them. So gearbox out and new friction plate, pressure plate and bearing fitted, I also had them replace the clutch master cylinder and the return pipe anyway. Car all back together and all good, although I'm €2400 lighter in the wallet!!!
Worth it though!!
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
Reffio
Re: Clutch renewal
Post by Reffio » Fri Jan 18, 2013 11:46 am
What determines if the flywheel needs done and what's the possible impact if you don't do it when replacing the clutch?
Tile Diver
Re: Clutch renewal
Post by Tile Diver » Fri Jan 18, 2013 1:13 pm
Reffio wrote:What determines if the flywheel needs done and what's the possible impact if you don't do it when replacing the clutch?
Take advice from who ever is doing the job on your car as long as you trust them with regards to the Flywheel condition, I think a worn Flywheel has a bit play in it or signs of excessive wear, there are people on hear that can let you know the specifics. I didn't replace mine when the rest of the clutch was done as the mechanic said it was totally fine, I hope I don't turn out to regret that decision.
Its the labour costs that kill you, so if the flywheel packs in 6 months down the line it's another gearbox out job, which at an Audi Stealer's will cost you around 8 hours labour which = Mega Bucks.
If the flywheel is seen to be in good condition then it's your call to get it replaced when the gearbox is out or not, I think a new Flywheel is around £700 / £800.
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Reffio
Re: Clutch renewal
Post by Reffio » Sat Jan 19, 2013 6:20 pm
Ok thanks. Definitely seems to be a tricky one with a lot riding on what the mechanic thinks of the condition of the flywheel. Would be gutting not to do it only to be hit a couple of months down the line with another big labour bill to do the job!
D8vil
Re: Clutch renewal
Post by D8vil » Sun Jan 20, 2013 11:44 am
So I thought I would update you all
I had the full lot done, flywheel clutch, release bearing,new bolts and return pipe
Flywheel and clutch from loba and fitting by Autotechnica, job done was £1600
Clutch feels a little heavier but I guess it may give over time
Loba flywheel was massively lighter than the oem dual mass flywheel and the Andy at Autotechnica said it was a better assembly than the oem.
I am glad I did everything as although the clutch was not slipping it was nearly worn flat and only less than 1mm left on the clutch
Thanks to si from Loba for the free delivery
Well next is brake discs and pads
Tile Diver
Re: Clutch renewal
Post by Tile Diver » Sun Jan 20, 2013 11:58 am
Good result D8vil, that should be good for a long time!
There is a good thread on changing front discs and pads on here if you fancy doing it yourself!! :nodder:
http://forum.rs246.com/viewtopic.php?t=96406
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Coaster
Re: Clutch renewal
Post by Coaster » Mon Jan 21, 2013 4:12 pm
My car is currently with an Audi dealer with the gearbox out awaiting their diagnosis of my sticking clutch pedal. It seems likely that they will agree with me that the car needs a new clutch. Bearing in mind that I have done 4,000 miles in less than 4 months since I bought the car from them what is the likely outcome? Would you expect them to recommend replacement of the flywheel as well?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 105 guests
