Does anyone else follow this?
Tile Diver
Post by Tile Diver » Sun Oct 28, 2012 8:46 pm
Just wondering if anyone else follows this?
Brake Bedding in procedure.pdf
(387.29 KiB) Downloaded 149 times
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
Noyjatat
Re: Does anyone else follow this?
Post by Noyjatat » Sun Oct 28, 2012 8:58 pm
Nope I just hope she stops when I push the middle pedal until the little yellow light comes on and she says "I need some new shoes!" then I take her shopping :D
And that's just the missus!
stu
Post by stu » Tue Oct 30, 2012 1:46 am
Well the dealers don't. But they'll wave the piece of paper in your face and tell you that they're not honouring the Audi parts warranty if it hasn't been done :bash:
In my experience at least.
So, do it or be prepared to say you did it if anything goes wrong. For the record, I've done it three times. And now I have ceramics :smile_smoking:
Brooner
Post by Brooner » Tue Oct 30, 2012 6:38 am
Very similar to this method i use and never had any problems with warped disks
http://zeckhausen.com/bedding_in_brakes.htm
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Reffio
Post by Reffio » Tue Oct 30, 2012 8:39 am
So this bedding in procedure should be done pretty much as soon as you get the car back from the stealers after installing new pads or discs (or both)?
Tile Diver
Post by Tile Diver » Tue Oct 30, 2012 12:16 pm
Reffio wrote:So this bedding in procedure should be done pretty much as soon as you get the car back from the stealers after installing new pads or discs (or both)?
Well, I followed it anyway just to be safe and hopefully I'll have some kind of comeback if there is a disc warping problem before the parts warranty of 2 years is up!!!
It was a ballache and took around an hour and a half, trying to find a quiet road for that duration is near impossible.
Reffio, I think thats the general idea but there is no chance of the dealer doing this for you, and I suspect they may not even mention it to the customer after they fit new discs and pads, I could be wrong though!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
adsgreen
Post by adsgreen » Tue Oct 30, 2012 1:48 pm
2 year parts warranty won't apply to "warped" discs. They have an additional very low mileage warranty often not much more than 3k miles (on other marques).
bedding in is always good to do and worth repeating regulary to keep things in tip top condition. Normal day to day driving can be harder on the brakes than driving them hard and can prevent "warping" from pad deposits. Also generally stops the more track focussed setups from squealing.
Tile Diver
Post by Tile Diver » Tue Oct 30, 2012 10:06 pm
adsgreen wrote:2 year parts warranty won't apply to "warped" discs. They have an additional very low mileage warranty often not much more than 3k miles (on other marques).
Thanks for the info man!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Dom81
Post by Dom81 » Wed Oct 31, 2012 9:38 am
Brooner wrote:Very similar to this method i use and never had any problems with warped disks
Same one as I've used - again, no problems
2007 Daytona RS4 Avant
Tile Diver
Post by Tile Diver » Wed Oct 31, 2012 10:41 am
All done, thanks to everyone's contributions!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Reffio
Post by Reffio » Thu Nov 01, 2012 3:45 pm
Oh well I guess it's another good excuse for tearing around in the car for a while! Although I as mentioned I'm not sure where you find a quiet bit of road to do the continued runs like that!
Tile Diver
Post by Tile Diver » Thu Nov 01, 2012 6:27 pm
Reffio wrote:Oh well I guess it's another good excuse for tearing around in the car for a while! Although I as mentioned I'm not sure where you find a quiet bit of road to do the continued runs like that!
Exactly, and your right It wasn't easy on the road, I had the hazards on most of the time in fear of someound coming into the back of me!!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
KernowPete
Post by KernowPete » Thu Nov 01, 2012 8:02 pm
Did mine on a local disused arifield. Only problem was the concrete runways are breaking up pretty bad and there were massive potholes absolutely everywhere :shock:
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
Tile Diver
Post by Tile Diver » Thu Nov 01, 2012 9:52 pm
KernowPete wrote:Did mine on a local disused arifield. Only problem was the concrete runways are breaking up pretty bad and there were massive potholes absolutely everywhere :shock:
Ideal, just not good for the DRS, hopefully no damage caused.
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
stu
Post by stu » Fri Nov 02, 2012 12:20 am
Yup, the only way to do it safely and without affecting other road users is by doing it at night. I work on an 'on call' basis overnight quite a lot so I did it at around midnight on a completely empty rural road: the road from Newcastle to Jedborough (basically I went to Scotland and back :) ). Brilliant road for the way back when I could drive unrestricted, just had to watch out for the sheep.
Users browsing this forum: No registered users and 136 guests
