New Brand Products
Reflect Russ
Trader (Expired)
New Brand Products
Post by Reflect Russ » Sat Oct 27, 2012 1:37 pm
Right then fellas....this is in the pipeline with PhilT...I have my own products that will care for your motors paintwork to the hilt....
What we have initially spoke of is whether you have the brand from me that is or would be endorsed by members of the RS246 forum or just RS246 branded products....
Now as i say this is just in the initial talk stages of which we have to have a catch up over the next week or so but thought i would just throw this out there for members input....
I will be in touch with PhilT once i have a few hours to spare him... :biggrin3:
brn7y
New Brand Products
Post by brn7y » Sat Oct 27, 2012 2:59 pm
If you want endorsements that will require free test samples!!
Re: New Brand Products
Post by chunky79 » Sat Oct 27, 2012 4:59 pm
Mr T is too slow sorting things out!!!!
Don't think it would bother me what the branding is on the products, as long as they are good I will buy. I think samples would be good though (not free obviously) so we can test the product.
Good luck whatever happens.
Reflect Russ
Trader (Expired)
Post by Reflect Russ » Mon Oct 29, 2012 9:47 am
I will try and get some sample kits together and work a price out....only have a few hrs today and thats it for a fortnight so please bare with me....
Post by chunky79 » Mon Oct 29, 2012 10:23 am
No problem
PhilT
RS246.com
Post by PhilT » Thu Nov 01, 2012 11:46 am
chunky79 wrote:Mr T is too slow sorting things out!!!!
Very true because Mr T has a day job.
chunky79 wrote:Don't think it would bother me what the branding is on the products, as long as they are good I will buy. I think samples would be good though (not free obviously) so we can test the product.
I would start with the 1NE. I have the 1NE and it replaces a number of other products like snow foam and shampoo. The great thing is it works like a dream and I only need one product which I dilute depending on what I'm using it for.
"There is only 1NE"
Post by chunky79 » Thu Nov 01, 2012 12:30 pm
I'm running low on snow foam so moar info required.
Reflect Russ
Trader (Expired)
Post by Reflect Russ » Tue Nov 06, 2012 10:43 am
Right guys as you know i have been able to get my hands on some rather special products....not the usual bandwagon jumping which seems to be the thing to do these days....
Controversial i know but i dont tend to follow suit if you know what i mean....
The product that I feel could and most likely should be the product of the year 2013 and has got many ears wagging is my 76% active ingredient cleaning solution....with it being so active the blend is down to you....
R1NE "The Breakthru"
As a foam i use a meagre 50ml in a litre foam lance and produce things like this....
Its active cleaning formulation not only lifts dirt....but shifts dirt....
As a shampoo around 15ml in a 10ltr bucket of water is sufficient for a maintenance wash but this can be adjusted to the level of grime you need to shift....but that wont be a lot after its been used as a foam....
It can also be used as a degreaser diluted at 1-10....a maintenance wheel cleaner at 1-20....but its that versatile you can pretty much do what you like with it....I have even used it as a clay lube....5ml in a litre bottle which just defies logic....that strength would clean light levels of dirt as well....
Its pH value is between 7 and 8.5 so is safe to used on pretty much anything....
I wont say it is wax and sealant safe because nothing truly is as degradation occurs after every wash no matter what others may think....
This comes in 500ml at £10...1000ml at £15 and 5000ml at £45....I can even supply a 25lt drum should any other pro on here feel the need to be stocked up on everything for a good length of time....
Next up is my sealant...
R5VE "LockDown"
Ptfe based and so easy to use....wipe on...wait 10 minutes and buff to a shine like these below....
With flake pop to die for....
And they are just a few....
500ml is £17.95
I also have a new wax blend that is made in my own home and made to order...this is more of a summer wax and is by wax content 100% grade 1 Carnauba....(around 30-35% by volume) it looks like this...
I also have a QD....
R2WO "TropiQD"
which adds gloss and depth to any colour it is applied to....again a wipe on wipe off but this you apply to the cloth first....
QD is £9.95 for 500ml...it can also be supplied in 5litres
I have others like galss and plastic AIO...Air Deoderiser....metal polish and even some strong cleaning agents for underneath the wheel arches and engine bays....
May i add that none of the cars in question have received any kind of machine work prior to the sealant and wax being applied...just a good old pre wax cleanse with either Raceglaze Pre wax cleaner or Lime Prime....
Prices do not include P&P...
I will try and put a few sample packs together and work a price out for those if needed...the only thing with sample packs is sometimes you dont get enough of one product and too much of another so you effectively run short in a kit....but if i were to put 250ml sample packs out there would be plenty....the sealant though would be 100ml as it will last a long time due to very little being used....
For enquiries PM me on here and i will reply as soon as i can....
***Just changed the offer on this for you guys...I have removed the 10% purely because as i use RM Dick Turpins at the minute the postage is stupidly high....a litre bottle is £5.60 to post and thats without packaging etc and a 500ml is £2.30....what i am going to do is Knock the postage down by around 50-75% so a litre would be plus £2 and 500ml would be plus £1....any other weights please get in touch***
You can pay via paypal at russell.reflectology@sky.com add your address details to the notes and also post transaction ID in this thread....
P_G
Post by P_G » Tue Nov 06, 2012 1:39 pm
Russ, I'll have a litre of snow foam, the Valet Pro stuff I have at present is utter garbage. I have a Karcher with the 0.6l grey foam lance vottle so how much in that to get the same results as you have photographed.? And how does one pay you?
Reflect Russ
Trader (Expired)
Post by Reflect Russ » Tue Nov 06, 2012 3:01 pm
had the same question asked on another forum mate with the exact same lance....the thing is with those lances they dont produce enough pressure to effectively mix and distribute the foam....but in all fairness the thickness of the foam doesnt really matter too much as most of them are just for show with a little dirt being drawn into the surfactants....
30ml in that bottle should do a stern cleanse on it mate but for foam thickness i am not sure what will happen but either way the product will be applied and will set to work without having to dwell too long....i have taken this stuff off after a couple of minutes and the results are far far better than my previous foam....
The flow rate through the lance will almost certainly have an affect on the thickness but IMO anymore than 30ml in that bottle and its just a waste of product....
As i say i have yet to try it on a standard manufacturer lance....
HTH
P_G
Post by P_G » Tue Nov 06, 2012 4:29 pm
TBH they work pretty well all considered, get great foam when on max concentration on the dial using Autobrite magifoam so if this foams as well as that then all will be well. Using Valet Pro Combi-foam and it is the worst foam I have ever used to the point it doesn't foam and doesn't lift dirt. Easier using Duragloss shampoo in my lance and letting it dwell and it does a better job!
Post by chunky79 » Wed Nov 07, 2012 6:48 pm
Russ, can you do a list of all the products you sell and the prices please? No major rush, I want some of that snow foam and possibly other stuff off you.
Dunc
Reflect Russ
Trader (Expired)
Post by Reflect Russ » Thu Nov 08, 2012 4:22 pm
I will copy and paste a list later....just off to pick van up from testing station....
Reflect Russ
Trader (Expired)
Post by Reflect Russ » Thu Nov 08, 2012 6:53 pm
Product Price List
R1NE- Breakthru
Ultra Concentrate All In One Solution....Active content circa 76%....
5000ml £45
1000ml £15
500ml £10
R2WO -TropiQD
Gloss Enhancing Super Slick Quick Detailer….
500ml £9.95
R3RE- GlasTastic
Glass and Plastic Cleaner…One product for both glass and plastic…
500ml £5.95
R4UR -Metal
Metal Paste that is perfect for those stainless Zorst tips….
250ml £7.95
R5VE -LockDown
PTFE based paint sealant that is quick and layerable….
500ml £17.95
250ml £12.50
all prices are exclusive of post and packing....
I am also testing some metalised plastic dressing and a tyre dressing that leaves a satin finish....
Post by chunky79 » Thu Nov 08, 2012 7:22 pm
Cheers for that Russ.
Is the Glastastic a spray or paste/liquid?
Users browsing this forum: No registered users and 74 guests
