LOBA RS3 362mm brake disc upgrade
2.5 I5 20v TFSI - 335 bhp
supersi
Post by supersi » Wed Oct 17, 2012 4:28 pm
LOBA Motorsport RS3 362MM Upgrade Rotor set-up (retains stock callipers)
AP Racing 48 Vane Directional rotors for the RS3 (Grooved or Drilled) Bolt On Replacement no other modifications to carry out (PLUG&PLAY)
Uses stock callipers, the assembly uses “ Float in the Bell” Technology, float is limited to 0.2mm compared to 0.5-0.7mm float disc systems such as Alcon or less capable AP racing setups.
Custom rate developed bobbin springs allow design axial and radial float whilst maintaining OEM levels of NVH.
Assembly's proven to demonstrate excellent heat management by design in testing due to axial flow of air from behind the bearing to the centre of the disc via 48 vanes and a 17mm air gap, provision is also made for front face cooling via recessed vents on the reverse bell face.
All components from rotors to washers are available separately this is truly a disc assembly for life, whole life cost is lower than OEM especially for tracked vehicles, Disc finishing is either radially drilled via CNC to avoid hotspots or curved grooved, rebuild and refinishing service facility available.
Optionally available with temperature sensing paint applied set to 430/560/610 degrees, Design requirements was nominally 10-12 track laps at competitive driver speeds, surpassed in initial testing by professional drivers
Disc Bell and bracket CNC machined by a supplier to race teams at the pinnacle of Motorsport
HEL braided steel brake lines
Disc Rotor is Supplied assembled
Rotor size is 362mm, thickness is 32mm, complete disc weight 8.7Kg
Price : 1,498.00 EUR inc vat (1,258.82 EUR without)
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
P_G
Re: LOBA RS3 362mm brake disc upgrade
Post by P_G » Wed Oct 17, 2012 5:07 pm
Damn you Si, I was hoping you wouldn't do these for a while yet! :bigblink:
Dave_Hedgehog
Post by Dave_Hedgehog » Wed Oct 17, 2012 7:05 pm
they look lovely but i am wondering when you would need them the stock brakes are mental for road use
supersi
Post by supersi » Wed Oct 17, 2012 8:02 pm
Dave_Hedgehog wrote:they look lovely but i am wondering when you would need them the stock brakes are mental for road use
Must try harder ! :bigblink:
Had many requests from owners of tuned cars and our LO500P RS3 upgraded cars, have sold a massive amount to the TTRS owners out there so must be a need
supersi
Post by supersi » Wed Oct 17, 2012 8:07 pm
P_G wrote:Damn you Si, I was hoping you wouldn't do these for a while yet! :bigblink:
HAHA Sorry ........have rear options also coming soon :biggrin2:
Carrg
Post by Carrg » Tue Oct 30, 2012 7:06 pm
Dare I ask the cost? :beerchug:
Ibis RS3 - Buckets - Bose - Black Ed - Privacy - Musical Brakes
VW California 180 DSG " Candy"
supersi
Post by supersi » Tue Oct 30, 2012 7:14 pm
Carrg wrote:Dare I ask the cost? :beerchug:
Sorry here you go 1,498.00 EUR inc vat (1,258.82 EUR without)
Other RS3 products also new upgraded high pressure fuel pump to be added soon http://www.loba-motorsport.com/en/produ ... ps-quattro
Users browsing this forum: No registered users and 9 guests
