starting problems
New to the forum? Say "hello"
bart1
starting problems
Post by bart1 » Sun Oct 07, 2012 7:18 pm
Can anyone help? i have an 06 rs4 with an intermitant starting problem. the car starts fine generally if its started every day, but if left for a couple of days wont start. it has been into audi 5 times now and they are struggling, they have replaced the cluth sensor 3 times but with limited success. the only way i can get the car started is by using jump leads from another car onto the terminals in the bulk head and it starts. the battery is fine before anyone says that. any comments please?
Nobby
Re: starting problems
Post by Nobby » Tue Oct 09, 2012 10:42 am
FON
Maybe post in the RS4 section
Daytona RS6 Avant
nukinukinuki
Post by nukinukinuki » Tue Oct 09, 2012 11:22 am
I have no idea if this could have anything to do with you're issue or weather this applys in this scenario but its worth the suggestion..
I had a motor with a similar issue many years ago.
It was a weak Starter motor that did not sound weak. If the ECU did not detect 250RPM from the Starter motor the ECU wouldnt allow any fuel through the injectors. 249RPM would disable it from starting.
It was diagnosed via OBD monitering the RPM values the ECU was reading. Combination of new battery + starter fixed it.
Could be worth just checking out.
adsgreen
Post by adsgreen » Tue Oct 09, 2012 12:56 pm
Hae have you determined the battery is "fine"?
Return to “Welcome Area”
