michelin pilot super sport tyres -any feedback
5.0 V10 50v biturbo - 571 bhp
perthwaRS6
Post by perthwaRS6 » Thu Aug 16, 2012 7:37 pm
Hi fellow C6 RS6 tragics, :bigwave:
I am considering fitting Michelin pilot super sports 275/35ZR20, Z speed rated, to the C6 RS6 replacing the current Dunlop Sport Maxx GT 275/35 R20 Y (102 XL) RO1.
Can anyone please advise if the load rating of the Michelin PSS is ok for the C6 RS6.
Also, if anyone has fitted the MIchelin pilot super sports to their C6 RS6, what is their experience?
Any advice appreciated.
regards,
john
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
doodlebug
Post by doodlebug » Thu Aug 16, 2012 7:55 pm
What is the load rating of the tyre above?
I've had OEM Dunlops since new and wouldn't change.
PorkaFly
Re: michelin pilot super sport tyres -any feedback
Post by PorkaFly » Thu Aug 16, 2012 9:25 pm
I have had MPSS on my C6 RS6 Avant since last Oct. Naturally the tyres I have fitted are the correct load and speed rating. Outstanding dry road performance, better wet weather performance than OEM tyre and even better wear than OEM Pirelli or Dunlops. They are slightly bigger than OEM tyres. Stick out more and have broader "shoulders" - I think this is to do with the better flatter contact profile/construction of MPSS. Tyre fitter was worried they wouldn't fit to start with so it's visually obvious and they give a more pronounced stance than OEM. Only criticism I have on RS6 fitment is they are slightly noisier ( but oddly not on my GT3. Another benefit is they are more supple and compliant, giving a smoother ride in Dynamic mode.
Tyre technology changes and these tyres are a major step-change in performance and wear, so a no-brainier in putting MPSS on RS6 - great tyre!
On my GT3 I have had a second set waiting to go on but still don't need to change them despite the abuse they've had.
They are nearly as sticky as Cups and have way better wear performance than old PS2s.
To put this into perspective - and you will struggle to believe this because I still can't - I have done 2xdays at Dijon-Prenois Circuit last August, 2xdays at Goodwood, 1xday at Spa (also very hot) and 2xdays at Le Mans-Bugatti (very hot) and they still have 3-4mm across all tyres. Sure, they have had numerous heat cycles but they stick, don't wear and here's the most important bit...in UK where it rains a lot, there is no way I would have cups on the GT3 (as intended) as any standing water makes the car dangerous on most roads. So MPSS a compromise as such on GT3, but an absolute winner on the RS6, and shudder to think how many sets of Cups I would have gone through doing the above mentioned tracks days. I don't struggle to keep up with others in similar vehicles with Cups on and I wouldn't say I'm a driving god, but certainly competent.
As you can tell, I'm a big fan of MPSS.
Get them at CostCo on a 20% off deal and you'll be smiling even more.
Hope this helps...
PF
2009 RS6 Avant (C6) - Monza
2011 GT3RS - Grey/Gold
2012 Range Rover 4.4 TdV8 Westminster - Black
Streem
Post by Streem » Fri Aug 17, 2012 10:42 am
Porkafly is absolutely right in everything he say's MPSS piss over everything wet and dry. The biggest tell is that the Dunlop's break away much earlier in the wet. They say "reinfoced" on the side this means 102Y which is the correct load rating.
C6NVS
Post by C6NVS » Fri Aug 17, 2012 11:10 am
Like it when Porkafly signs in...always sound advice with good reasoning
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
adam_
Post by adam_ » Fri Aug 17, 2012 12:58 pm
I made exactly the same switch and haven't looked back - wet and dry grip are totally transformed.
perthwaRS6
Post by perthwaRS6 » Sun Aug 19, 2012 11:08 am
Hi fellow posters, :bigwave:
many thanks for the feed back. Greatly appreciated. This feedback makes this a great forum for us RS6 tragics. :bowdown:
I am buying a set of four MPSS from tire rack out of USA landed at my door step here in Perth after all taxes at gbp 1200.
Not as cheap as UK, but a lot cheaper than Oz price for four of gbp 2600!
regards,
john
sakimano
Post by sakimano » Tue Aug 21, 2012 3:30 pm
Michelin PSS are fantastic. Great grip. Great handling. Look nice. Wide section widths (relative to their posted widths). Reasonable tread life. Fairly priced. Light as hell (reducing rotational mass is very beneficial for acceleration).
I would say you would be crazy to not give them a try, all else considered.
Post by bam_bam » Tue Aug 21, 2012 6:05 pm
I've been running them (275 30 19r) on my C5 for a couple of months. They're a square tyre but it shouldn't bother the C6, it has insane amounts of dry grip but it's not as good in the wet (I was coming from GY F1 Asyms 27 30 19r). A no brainer if you lived somewhere dry.
PorkaFly
Post by PorkaFly » Fri Aug 24, 2012 6:50 pm
C6NVS wrote:Like it when Porkafly signs in...always sound advice with good reasoning
Very excited I have a fan-club! :bigwave:
gdavison
Post by gdavison » Fri Aug 24, 2012 9:10 pm
bam_bam wrote:A no brainer if you lived somewhere dry.
Err we (and you) live in the UK ,, its crap re weather most of the time .. :knob:
gdavison
Post by gdavison » Fri Aug 24, 2012 9:11 pm
:biggrin3:
Post by bam_bam » Fri Aug 24, 2012 9:52 pm
Very observant of you but the OP is Australian and he's based in Australia, where the weather isn't crap most of the time. Can you see where I'm going with this... It's not all about us, don'tchaknow?
RS04YOB
Post by RS04YOB » Sat Aug 25, 2012 9:47 am
I will be going for these when I get my 20s on
morginator
Post by morginator » Sat Aug 25, 2012 1:35 pm
Alas I have heard this al before, but are there any MPSS for sale in this country (UK) that is
Users browsing this forum: No registered users and 97 guests
