Clutch Switch
Pyrotechnic
Clutch Switch
Post by Pyrotechnic » Sat Aug 04, 2012 2:45 pm
Picked up a new one this afternoon as I was having the rising revs/hold the start button/no cruise control problem, but got home to find the old one and new one look completely different:
Old: (8EO 927 189)
New: (7H0 927 189)
Didn't want to install the new one as I'd read it was a one-time-only affair, so I just swapped the plug over. This didn't seem to work make any difference. So after some umming and arring, I went for it and installed it, still made no difference, still have to hold the starter to start.
Have I got the wrong part, or am I doing something wrong?
PeteS4
Re: Clutch Switch
Post by PeteS4 » Sat Aug 04, 2012 4:06 pm
When I had mine replaced 18 months ago, I was told the switch had been improved and updated.
B8 S4 Black PreFL Avant
Previous: B7 RS4 Sprint Avant, BMW Z4 3.0 Coupe, TT MK2 3.2, TT MK1 225 Coupe, B5 S4 Avant
eightfoot
Re: Clutch Switch
Post by eightfoot » Sat Aug 04, 2012 4:49 pm
did you press the pin in when you just switched the plug,if so you broke it
Pyrotechnic
Re: Clutch Switch
Post by Pyrotechnic » Sat Aug 04, 2012 4:54 pm
eightfoot wrote:so I just swapped the plug over. This didn't seem to work make any difference. So after some umming and arring, I went for it and installed it, still made no difference, still have to hold the starter to start.
As in, did I depress the plunger? Yeah, I might have had a fiddle...
But, the plunger depresses when you insert it into the bracket before you twist it anyway, so I don't see how you can avoid pressing it at some point?
eightfoot
Re: Clutch Switch
Post by eightfoot » Sat Aug 04, 2012 7:16 pm
if you press the plunger in without turning the switch 90* (ie fitting in bracket) then you will brake it (i know :bigblink: ) if you take it out and shake it you will hear the broken bit inside,get a new one and fit it without fiddling with it just take it from the box and fit,you should be able to short the switch plug to see if it cures your prob as its just a 2 pin on/off switch but dont drive like it just check if your start button works without holding down,start button should also stop working if you let the clutch up before its started
Pyrotechnic
Re: Clutch Switch
Post by Pyrotechnic » Sat Aug 04, 2012 7:49 pm
Turns out you should just ignore me. Just gone out for another play, and everything's working fine. Starts by tapping the button, cruise control's back, and I think the revs are normal. Cheers for the help though.
ROY
Re: Clutch Switch
Post by ROY » Fri Sep 07, 2012 12:45 pm
Just changing clutch switch so i know its been done, got old type fitted at mo
Also reverse switch because ive had the reverse lights sticking
7HO927189 Clutch Switch
01E941521B Reverse Switch
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
ROY
Re: Clutch Switch
Post by ROY » Sat Sep 08, 2012 7:43 pm
Replaced my upper clutch switch today
Gearchange recently has been pretty rough especially in 1st and 2nd (no issues with cruise control or start button)
I thought i'd try the switch and wow what a difference.
All round improvement - worth doing :thumbs:
To get to the switch you need to remove the lower dash panel
3 x screws
Twist and turn the switch and remove, then disconnect the plug.
Push plug onto new switch (being careful not to touch the plunger at the end)
Push new switch in and twist and turn
Refit panel
Have a brew
Job done :thumbs:
I replaced clutch switch A (there are 2)
Old switch on left, New modifed switch on right
Spaceman_RS4
Re: Clutch Switch
Post by Spaceman_RS4 » Sat Sep 08, 2012 8:51 pm
Quality pics and advice there Roy. Mine is just like yours by the sound of it I'm going to change the switch too.
Cheers Greig
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
TonyHayers
Re: Clutch Switch
Post by TonyHayers » Sun Sep 09, 2012 3:39 pm
This isn't the case with the new part number, that advice applies to the old part number.
06 Phantom Black Saloon:
^ GONE :cry:
Spaceman_RS4
Re: Clutch Switch
Post by Spaceman_RS4 » Sat Sep 22, 2012 3:52 pm
I have just changed this clutch switch wow what a difference the car is so smooth and easy to pull away and smooth gear changes.
My cruise and start was working fine btw.
Cheers greig
ROY
Re: Clutch Switch
Post by ROY » Sun Sep 23, 2012 10:52 pm
Me too spaceman_rs4
Same i had no start issues or cruise issues. :thumbs:
What is the other switch for :?: ?????? Switch B in my pic
Spaceman_RS4
Re: Clutch Switch
Post by Spaceman_RS4 » Mon Sep 24, 2012 7:45 am
No idea bud I never looked, I was just in and out but geez it's like a different car so happy I changed it .
Mine-was original one and was a touch black.
brn7y
Clutch Switch
Post by brn7y » Fri Oct 12, 2012 6:53 pm
Swapped today, easy 5min job.
Not had chance to try yet as it is pissing down and she's staying tucked up in bed.
My original was quite worn at the end.
Bobfin
Re: Clutch Switch
Post by Bobfin » Tue Oct 16, 2012 5:51 pm
I replaced the clutch switch, this solved the issue with the cruise control but i still have the revs between gear changes and the engine start switch has to be kept depressed, could i have damaged the plunger when installing.
Users browsing this forum: Google [Bot] and 66 guests
