Slow to change gear?
Compared to my TTS, my RS3 is really slow to respond to gear changes using the paddle or stick. Sometimes it seems to refuse to up-shift as well, typically when pulling out of a side street with a bit of extra throttle (nothing too hard, mind).
Does this sound like normal behaviour or is a trip to the dealer in order?
- Dave_Hedgehog
- 5th Gear
Re: Slow to change gear?
cold oil?
they do learn tour driving pattern and can be a bit slow when adjusting to your driving style
The Hedgehog, creator of RS4.org, back in of the RS fold yet again, third time lucky
Could be cold oil as it is more pronounced when the car is cold.
I didn't think the car did any learning in +/- mode, just in D and S?
- Dave_Hedgehog
- 5th Gear
Could be the mecatronic unit, wouldn't be the first with an issue, easy fix thou
Yep. Guess I'll book it in...
I'd get it looked it. My changes are very fast and responsive.
Steve
Steve
2011 Audi RS3 Daytona Grey | 2003 Audi RS6 Avant Ebony Black
Thanks again, I'll definitely get it looked at.
I also have some inconsistencies in the gear changes, mainly when manually changing. Car is booked in for next week for a check up
There are some TPIs out with regard to TTRS/RS3 shift profiles.
Definitely get it looked at.
Could just require a software update.
funkygibbo
- 1st Gear
Nope, gotta say, no issues with changes either in manual or sport mode.........get it checked out!
Ok, car went into the dealership today but they couldn't reproduce the problem. The master-tech checked out my car and looked for error codes on both the engine and 'box - none showed. That's ok, the problem normally happens quite predictably when the car is stone cold so it will go back to the garage next week to stay overnight and on the next morning I'll take the master-tech for a ride and see about demonstrating the problem. Luckily I'm a professional system tester so reproducing problems is an established skill for me
Interestingly there is a technical note against the RS3 regarding adaption and how this process can result in it feeling jerky for a period.
I'll attempt to reproduce the problem again myself in the morning and his time I'll video it - you forget that you have a HD video camera in your pocket all the time these days!
Stoo. wrote:There are some TPIs out with regard to TTRS/RS3 shift profiles..
dbm wrote:Interestingly there is a technical note against the RS3 regarding adaption and how this process can result in it feeling jerky for a period.
The technical note basically said "it's not a problem" - nothing to sort?
Well I'll tell you this, he needs to have another look
Which dealer is it?
Which dealer is it?
Preston. Have you got any kind of reference number I can quote?
Users browsing this forum: No registered users and 52 guests
