An LED number plate light that works?
Has anyone tried these on for size yet? Not cheap.
http://www.jdmpowered.com/audi-rs4-06-0 ... 1305-p.asp
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
Re: An LED number plate light that works?
I bought these...
http://www.ebay.co.uk/itm/Audi-A4-B6-S4 ... 3370110699
Had them in my C6 RS6 now for two months....very good quality...nice crisp light...and no errors at all.
Chris.
Chris.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
I used these from Ebay and they fitted okay no problems. Think look the same make as above.
http://www.ebay.co.uk/itm/270695994121? ... 1423.l2649
Also check out these if you want interior LEDs
http://www.ebay.co.uk/itm/280696913699? ... 1423.l2649
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
Many Thanks Gents
LED interior light set ordered
- voyager162
- 1st Gear
i ordered those led number plate lights from ebay fitted today and they throw up an error
pain to bag em up an send them back so will prob fit the correct resistor to get them working, but just a heads up if anyone was thinking of ordering.
That's weird - mine was okay? They also say no-canbus error - mmm a bit of a pain in the a&se.
Which ones did you order from ebay voyager - the ones RS6Chris bought (which are just bulbs) or the ones Gavla bought (which are the complete unit)?
As i said above mine are spot on....in a C6 RS6.
Dont know if the B7 RS4 has something different on the electrical side of things??
Bearing in mind my rear lights are OEM LED so dont know if this would have an effect on number plate bulbs??
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
It seems that these led bulbs work on some and not others. Mikefish on here has the led complete unit bulbs from eBay (see "another led bulb thread") and they work fine on his with no errors.
As i understand it There's two things - 'no can bus error' relates to an ecu method of checking for blown bulbs.
The b7 rs4 just uses a basic resistance check and isn't can bus so will show an error.
The JDM powered units purchased are installed and work fine, no errors. I did need to fit a screw with a fractionally smaller head but used the opportunity to replace the original screws with some stainless steel ones. In fact the lamp units themselves are probably a slightly better quality than OEM!
- voyager162
- 1st Gear
if it ever stops raining i'll get out and check resistance and see if there is a huge difference.
I just ordered these
hopefully they will work
http://www.ecstuning.com/Audi-B7_RS4--V ... ES2526327/
I bought the ECS tuning ones 3 months ago... and ***error***... after a call to ECS... they said to return them... with the ones you show... they claim no errors...... the quality of the ones I bought looked good.. but fit was a BITA... as i had to enlarge the screw holes...
ECS does not seem to be very good differentiating between B& RS$ and misc A4 products... as their online catalogue lists all sorts of none RS4 parts, even though you specify t he make and model up front... i
I bought the exact ones that Gavla linked from eBay and have had no problems. I previously tried to change just the lamps and got errors.
Users browsing this forum: No registered users and 358 guests
