Massive boost leak
Mr V10
Massive boost leak
Post by Mr V10 » Sat Jun 09, 2012 11:26 pm
Had a cousin pop over and he wanted a spin in the car, took him out and it was running flawlessly, going like <beep> off a shovel, then I thought I heard a weird noise, turned the music down and it got louder and louder. It sounds like someone letting air out of a tyre but 100x louder, I couldn't hear my exhuast it has become that loud. It only does it when it hits 3,000 RPM. There is no real noticeable performance reduction. Anyone had this? I've made two videos to try and demonstrate the noise but it is hard to capture. It sounds as it if it is coming from the drivers side, intercooler hose popped off?
http://www.youtube.com/watch?v=SLkKpTKZ ... ata_player
http://www.youtube.com/watch?v=0vXFrRU_ ... ata_player
PJC
Re: Massive boost leak
Post by PJC » Sat Jun 09, 2012 11:32 pm
Hope its nothing serious.
RS6JJL
Post by RS6JJL » Sat Jun 09, 2012 11:36 pm
be a hose somewhere deffo jubilee clip come loose on intercooler bumper off jobby
get Vagcom on it for fault code?
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
RS6MAN
Massive boost leak
Post by RS6MAN » Sat Jun 09, 2012 11:43 pm
Has happened in my previous rs6; it was the pipe connecting the turbo to i think intercooler? It had come loose...
Mr V10
Post by Mr V10 » Sat Jun 09, 2012 11:43 pm
Lost my Vag Com. :bash:
Car is having the intercoolers done at Unit 20 in a few days anyway, so could leave it until then, or I could get it to MRC before then if Doug can book me in, don't fancy driving up to U20 when the car isn't right and I bet the AA wouldn't recover unless it physically broken down. :audibash:
Rs6spec
Post by Rs6spec » Sat Jun 09, 2012 11:51 pm
I had mine do this, a bottom intercooler pipe had popped off, need a new rubber pipe as it had "shrunk" think it was about 70 pounds :-/
Had it repaired outside my house, maybe a AA man could put a new one on If you get the part from Audi? I had my old one put back on. It it kept popping off, so put a new one on! maybe AA could temp repair before you trip away?
perthwaRS6
Post by perthwaRS6 » Sun Jun 10, 2012 4:37 am
Hi Amar, :bigwave:
I had the same thing happen to me with the passenger side hose to the intercooler. Take the engine undercover off, remove the bottom intercooler hoses-clean all the oil away and then replace and tighten till get the new wagner or venair silicone boost hoses and hose clips. Oil from the charge mixture gradually weakens the grip of the oem rubber hoses so they slip off. :audibash:
Also check that source of external oil on hoses, if there, not coming from leaking rocker cover gaskets.
john
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
swannny
Post by swannny » Sun Jun 10, 2012 6:14 am
Similar thing to mine, bottom hose popped off, I replaced them with wagners hoses.
Still got my old ones though Amar if you want me to post you some spares?
Nobby
Post by Nobby » Sun Jun 10, 2012 6:58 am
You could get some Mikalor clamps too, they are much stronger than jubilee clips
Daytona RS6 Avant
Post by Shoppinit » Sun Jun 10, 2012 7:50 am
It happens to everyone at some point; Consider it losing your intercooler virginity. You've already fooled around and got to base 2 with the holes in them, now you've popped your cherry.
Easy fix. Get the car in the air, sump shield off, and you'll see the intercooler hose that's come off. Put it back on and tighten that jubilee clip as much as you dare. And then some.
Post by Shoppinit » Sun Jun 10, 2012 7:51 am
I like the look of those Mikalor clamps.
posterboyj
Post by posterboyj » Sun Jun 10, 2012 9:36 am
JCS Hi Grip hose clamps; I highly rate.
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
Post by Shoppinit » Sun Jun 10, 2012 9:38 am
Yoda?
Simon T
Post by Simon T » Sun Jun 10, 2012 10:45 am
Could be time for the wagers.
Daytona RS6 Avant, PSS9, Milltek system with 100 cell, Wagners & hoses, MRC map / 533 ps & 865 nm. Phaeton Ducts. Daily drivers / VW T5 and R1.
imacool
Post by imacool » Sun Jun 10, 2012 10:56 am
Sorry to hear your problems, Amar.
As it happened all of a sudden, 90% chance it will be the popped off bottom hose, as others mentioned. If you can get your car on the ramp, it shoud be no problem to get it sorted.
Good luck with repair and please, keep us updated!
current: Quartz Grey A6 C6 Avant 3.0 TDI Le Mans
prev:Daytona grey RS6 C5 Avant,Black BMW 320D Coupe (E92),Red Honda Accord 1.8
Users browsing this forum: No registered users and 90 guests
