Autopsy of a TPM Sensor
Post by Shoppinit » Tue Jun 05, 2012 1:51 pm
I always wondered whether it was possible to change the batteries in these, rather than stumping up for new units. Well, I have just replaced all my TPMS so I thought I would sacrifice one of the old ones in the name of science to see if there could be a method of getting to the battery and replacing it, thus giving a new lease of life.
In short, I would say that it's a no-go. You have to destroy the casing to get at the battery which is soldered onto the PCB and then smothered in hard resin. I went in from the back of the sensor, suspecting that the battery would be just under the rubbery resin. It wasn't, the PCB was, and the battery is soldered to the other side of this PCB. I prised the PCB out, destroying it and ripping the tracks where the battery is soldered.
In this photo you can see the battery on the left under a white plastic cover that lets the contacts protrude through. These contacts are soldered onto the PCB on the right. The PCB is as it came off the sensor, so the contact points avec the battery are hidden.
With the PCB flipped over you can see circled where the battery was soldered:
And now with the battery removed. The resin (brown) around the sensor and on the outside of the sensor is quite rubbery and easy to remove. The resin (white) holding the battery in place is much harder, but like compressed powder. I eventually prised the battery out of it, damaging its case:
I had a go getting at the battery from the other side by cutting the case with my dremel. I could get the battery out, but not without destroying the PCB.
So in conclusion, I think it's not a practical proposition to try and change the batteries in these things.
Mr Footlong
Re: Autopsy of a TPM Sensor
Post by Mr Footlong » Tue Jun 05, 2012 5:03 pm
Bah, what are you talking about man, clearly super glue and a solder gun will fix that right up.
Current:
Gone:
amanda1
Post by amanda1 » Tue Jun 05, 2012 5:42 pm
Mr Footlong wrote:Bah, what are you talking about man, clearly super glue and a solder gun will fix that right up.
Maybe but..........is it worth the effort!!!!
950 nm torque!
Mr Footlong
Post by Mr Footlong » Tue Jun 05, 2012 5:47 pm
It was a joke darling...
Current:
Gone:
Return to “Electrical”
Users browsing this forum: No registered users and 9 guests
