Oil leak, eek....
Oil leak, eek....
Hey all,
Drove from Glasgow to Tewkesbury today, stopped near Brum cos the oil light came on, chucked half a litre in, 30 mins later the oil light came on again.... Got to Tewkesbury ok but there's oil around the front offside bumper. Oil cooler?
If I find a garage nearby and it is the oil coller, can it be bypassed to get me home tomorrow?
Re: Oil leak, eek....
I would say not , make sure they are very carful removing the old pipe , if they do it wrong you'll end up paying for a cooler as well ...
Unit 20
0151 3366888
0151 3366888
had the same problem a month or so ago, went in to audi for checks, it appears the rad had taken a hot, either kerbside to pothole (so they told me), i knew it was impossible as we'd had the car back from them for a day, argued the toss and said they'd caused the damage. thankfully £1800 bill was picked up by them, just check there;'s no damage to the rad, visible fro under the front spoiler.
Hope it's not that !!
cheers
M
cheers
M
The Gone List.......
911C2S, BMW735D, Audi A2, Cayenne S, 911 turbo, 911s, Range Rover, audi 2.6se, BMW X5, BMW M3, Ferrari Mondial, BMW 318ti, Shogun, Fiat Uno, 5 turbo, clio williams, 911 c4 cab, 911s, sapphire cosworth, Cooper S, Audi A4 Cab, BMW 735, BMW 740, BMW 535, Golf GTi 16V, mini metro
And not letting go of the RS4 !!!!! (Yes I know, it's gone, but never forgotten) !!!
Oil leak, eek....
Very likely it's just a pipe but where these pipes connect to the oil cooler the two different metals of the cooler and pipes accelerate the natural corrosion process and it means that they are a right pita to remove. In some/many cases removing the pipe damages the oil cooler and its a replacement cooler job.
I know as I had my pipes changed as they were beginning to corrode but it cost me an oil cooler even though they were careful when removing them!
Good luck!
Good luck!
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
As above - you have to cut the pipes off carefully.
If you cut the fixing bolt then you can remove it as two halves and prevent damage to the cooler.
If you just use a spanner then as the nut is seized to the pipe it just trashes the (expensive) oil cooler connections.
+1 MRC cut mine off but the thread of the oil cooler simply peeled away with the pipe fixing!! I have the sneaky suspicion Audi had replaced these pipes on mine in the past and not done the best jobadsgreen wrote:As above - you have to cut the pipes off carefully.
The key thing is that whomever does the work knows they have to be so very very careful.
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
Thanks all.
Had it checked at Autostation here in Tewkesbury and the pipes have split. Waiting for a tow to MRC. Best course of action as far as I can see. There's oil all over the brakes, might need new pads?
- Teutonic Tuner
- 2nd Gear
Hope you get this sorted matey, I can't believe such a simple design fault has made it to production. Oil pipes like this should never fail for such a poultry reason!
I would really like to look into getting some aftermarket fittings/pipe put together to fix this issue. Would it be possible for you to salvage the old oil pipes when removed and send them to me so I can use as a template? I'll cover any postage costs etc of course. Would appreciate it, let me know.
Sprint Blue B7 RS4 gone but not forgotten...
Oil leak, eek....
Thats a great idea! Think it is not as a clear cut solution as this though as I asked Doug about running aftermarket and he said it was probably going to cost more than it was worth to do it.Teutonic Tuner wrote:Hope you get this sorted matey, I can't believe such a simple design fault has made it to production. Oil pipes like this should never fail for such a poultry reason!
Good luck though I hope you come up with something!
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
Hedgehog Dodger
- 2nd Gear
Could braided hoses not be used? Is there are threaded lugs on the inlet and outlet of the cooler couldn't you just used them instead?
I love drag racing and track racing. I have had many fast cars and below is a short list of the ones most memorable.
MR2 Turbo REV2 (standard) > MR2 Turbo REV1 300HP> MR2 Turbo REV3 450HP (Nick Name Biscuit tin) > Celica GT4 ST205 WRC 300HP > R32 GTR 425HP > Honda Integra DC2 (standard) > EVO GSR 300HP > R32 GTR 450HP
Now on the hunt for an RS6
- Teutonic Tuner
- 2nd Gear
Yep, the OEM pipes are made up of a mixture of braided hose and galv pipe from what I can see so replacing it all with hose is a possibility as long as the bend radii of the pipe is suitable, then as long as you can get fittings in the right size/thread to fit the rad you're half way there. The tough bit is the pipe ends that connect into the engine block/sump as it looks like a push-fit held in place with a bolt on a tab and this doesn't look like an off-the-shelf fitting, so an old pipe would need to be used here.Hedgehog Dodger wrote:Could braided hoses not be used? Is there are threaded lugs on the inlet and outlet of the cooler couldn't you just used them instead?
- Teutonic Tuner
- 2nd Gear
I'll get intouch with Doug, cheers.irvind wrote:If you're in touch with Doug feel free to ask him, it's cool with me!
I did similar on a bike. Retained the fittings on the sump, but had a raised edge braised onto them, then the appropriate braided hose was fitted with a jubilee clip end fitting - worked perfectly longterm.
Users browsing this forum: GhiniRS4, Google [Bot] and 125 guests
