LOBA TTRS front 8 Pot upgrade brake kit
2.5 I5 20v TFSI - 335 bhp
2.5 I5 20v TFSI - 355 bhp (Plus)
supersi
Post by supersi » Fri Mar 30, 2012 6:18 pm
LOBA TTRS front 8 Pot Brake Upgrade KIt
48 Vane Directional rotors
Bolt On Replacement no other modifications to carry out  comes with all needed hardware (PLUG&PLAY)
The assembly uses " Float in the Bell" Technology
float is limited to 0.2mm compared to 0.5-0.7mm float in float in the disc systems such as Alcon or less capable AP racing setups
Custom rate developed bobbin springs allow design axial and radial float whilst maintaining OEM levels of NVH
Assembly's proven to demonstrate excellent heat management by design in testing due to axial flow of air from behind the bearing to the centre of the disc via 48 vanes and a 17mm air gap, provision is also made for front face cooling via recessed vents on the reverse bell face
All components from rotors to washers are available separately this is truly a disc assembly for life
Design requirements was nominally 10-12 track laps at competitive driver speeds, surpassed in initial testing by professional drivers, kit currently being used on a tarmac rally TTRS
Disc Bell CNC machined in the UK by a supplier to race teams at the pinnacle of Motorsport
Disc Rotor is by AP Racing and is cast in the UK
Disc finishing is either radially drilled via CNC to avoid hotspots or curved groove rebuild and refinishing service facility available
Disc Supplied assembled & weigh only 8.7kg each disc
Rotor size is 362mm thickness is 32mm (drilled or grooved discs available)
uses a pair of supplied brembo 8 pot callipers (Optionally available colour of your choice)  and comes with braided steel brake lines
Choice of a range of pads to meet your needs
Optionally available with temperature sensing paint applied set to 430/560/610 degrees
Please email for a price as pad options varies due to pad choice
S.sharp@loba-motorsport.com
Image[/quote]
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
Timster
Re: LOBA TTRS upgrade brake kit
Post by Timster » Sat Mar 31, 2012 12:05 am
DK ?
Return to “TTRS / TTRS Plus (Mk2 Typ 8J) 2006–2014”
Users browsing this forum: No registered users and 46 guests
