Alarm / key problem
Supraholic
Alarm / key problem
Post by Supraholic » Fri Mar 23, 2012 9:18 pm
Sorry, I've done quite a few searches but can't find the answer; also can't find the handbook.
The other night I found one of the keys wasn't working, so I tried the battery from the other one and then neither of them worked; brilliant.
So I googled & found a reset procedure; open with one key, put ignition on, close door, lock with other key, press and hold both buttons until it does one beep of the horn.
Well that kind of worked; the key from the second half of that now operates the central locking but then I put it in the ignition & the alarm goes off. Turn it more and it starts the car but the alarm is still going. Lock it on the central locking and the lights are still flashing. Unlock with the central locking, ignition on, alarm sounds.
Have tried various versions of the reset procedure including another I found on here but the alarms still goes off when the ignition is put on. :boohoo:
Have disconnected the battery now as it's outside my neighbours bedroom!
Interestingly we had a wet passenger side carpet until about a month ago but stopped using the rear wash-wipe until we take her for a service so I doubt if that's the problem.
Thanks for reading/helping!
Re: Alarm / key problem
Post by Shoppinit » Fri Mar 23, 2012 10:03 pm
When you say the key wasn't working, you mean the remote?
Can you start the engine with both keys? Even if the alarm is going off?
Supraholic
Post by Supraholic » Fri Mar 23, 2012 11:08 pm
Presumably it was just the remote but I didn't check the key when the remote didn't work.
I'm not sure if I can start the engine with both keys, will try in the morning when the noise will be more acceptable to the neighbours.
sweegie
Post by sweegie » Sat Mar 24, 2012 11:56 am
Does the immobilizer light go out on the dash with the keys in the ignition?
Recycling dinosaurs for fun
Supraholic
Post by Supraholic » Sat Mar 24, 2012 6:38 pm
A night with no battery seems to have done the trick!
Thanks,
Christian
Users browsing this forum: No registered users and 284 guests
