Headlight Bulbs Change Procedure ?
lugars4
Post by lugars4 » Fri Mar 09, 2012 3:26 pm
Has anyone changed their headlight bulbs? I have just had to buy 2 new ones due to flickering when cold.
I hope to change them soon and would appreciate any feedback on what is involved before i start.
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
RSKiwi
Re: Headlight Bulbs Change Procedure ?
Post by RSKiwi » Fri Mar 09, 2012 4:32 pm
Begin process of swapping over.
Remove will to live.
I know that was of no help but I am sure someone will be along shortly to help....
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
R33
Post by R33 » Fri Mar 09, 2012 5:08 pm
Mine are flickering when cold too, I wondered what that was, so are they on the way out then? Can someone point me to a link for new ones please?
klauster
Post by klauster » Fri Mar 09, 2012 5:40 pm
mine were flickering when cold, just bought some new bulbs and all is well now ;)
its a fiddle job though
HEo2TEC
Post by HEo2TEC » Fri Mar 09, 2012 6:21 pm
Are they d1s bulbs ?
spikeyboy101
Post by spikeyboy101 » Fri Mar 09, 2012 7:27 pm
One of mine xenons is flickering as well - damn annoying.
What bulbs do I need and where is best place to source ? And roughly what price.
rs4blacked
Post by rs4blacked » Fri Mar 09, 2012 7:40 pm
You may need the ballast unit on the back of the bulb too, My headlights flicker (Xenon's) and on the odd occasion shut down, According to Audi there is a technical update that says new updated bulbs and ballasts are needed at a cost of £1100 for the the lot fitted think I'll wait till they do fail totally.
Currently Mondeo ST155 & Titanium X Sport
RS4 Phantom Black, Black Optics, Tech Pack, Milltek Non Res Non Valved
klauster
Post by klauster » Fri Mar 09, 2012 7:42 pm
I uprated my bulbs to philips ones, whiter and brighter, cost me £100 ish, I wouldn't go for the cheap ones but thats just me, I didnt need anything but bulbs D1S's
klauster
Post by klauster » Fri Mar 09, 2012 7:44 pm
klauster
lugars4
Post by lugars4 » Fri Mar 09, 2012 9:50 pm
I believe these are the OEM fitment.
http://www.ebay.co.uk/itm/150756558484? ... 340wt_1270
HEo2TEC
Post by HEo2TEC » Sat Mar 10, 2012 8:19 pm
lugars4
Post by lugars4 » Sun Mar 11, 2012 7:50 pm
I changed the bulbs today. Not worth attempting it with the bumper on.
Remove Bumper.
Remove top torx srew from headlight.
Loosen 2 side screw a couple of turns.
Remove headlight, disconnecting the cable.
There is a panel on the rear of the light, 2 x torx screws hold it on, then the buld can be changed.
Reverse of the above.
The headlight will need to be aligned using VAGCOM
The bumper alignment is fiddly, the two adjustable mounts have to be adjusted a number of time until it looks right, removing and replacing the bumper (enough to adjust the mounts) each time.
Total about 2 hours, not rushing about.
The bulbs fitted were identical to these: Philips Xenstart D1S 4300K http://www.ebay.co.uk/itm/150756558484? ... 340wt_1270 Which i have replaced them with.
Hopefully the flickering will be gone! I will update shortly.
adsgreen
Post by adsgreen » Sun Mar 11, 2012 8:23 pm
Elsawin documents the process for full in place bulb changes.
Drivers side:
Essentially you need to remove the entire airbox and airfilter housing. Useful if you want to check the airbox power flap at the same time.
- remove air box snorkel (two screw on the bumpe)
- unplug MAF sensor
- Detach hose to secondary air pump.
– Detach vacuum hoses (air box power flap)
– Detach air hose -3- at air mass meter.
– Screw out bolts and detach top section of air cleaner housing.
– Disengage holder for wiring harness at body.
– Detach clip and take out air cleaner housing with air mass meter
Passenger Side
Essentially unmounting the washer fluid and power steering resevoirs
- Unscrew 1 nut and 2 bolts from the resevoirs. (nut is on the side of the washer fluid bottle, one bolt on the power steering and one bolt that is shared between both resevoirs).
– Remove breather hose from top section of washer fluid reservoir.
– Detach top section of washer fluid reservoir and move power steering reservoir to side with hydraulic hoses still attached.
Overall both not too bad but still far too much effort for such essential bulbs.
rs4blacked
Post by rs4blacked » Sun Mar 11, 2012 10:13 pm
that is just mad having to remove loads of stuff to replace the bulb.
Though when i worked for BMW the E65 7 series charged 1.5 hours to change the headlamp bulb
Users browsing this forum: Bing [Bot] and 1724 guests
