First try of the Vag com
wardy124
Post by wardy124 » Sat Jan 21, 2012 10:28 pm
Hi all,
I've just bought a Rosstech cable from a fellow member paulm, ran an auto-scan and came up with the following faults,
Saturday,21,January,2012,13:38:52:10880
VCDS Version: Release 11.11.1 (x64)
Data version: 20111209
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 Q
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2F6700EFED066CC
1 Fault Found:
01592 - Air Quality Sensor (G238)
37-10 - Faulty - Intermittent
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H46 0650
Revision: 03S Serial number: AUZBZ7D0010652
Coding: 0309111
Shop #: WSC 61930 512 00000
VCID: 244DFFC3E4C0DF4
6 Faults Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 5
Fault Frequency: 192
Reset counter: 2
Time Indication: 0
Date: 2010.06.18
Time: 10:33:15
Freeze Frame:
Mileage: 655350 km
Count: 1007
Clock: 11:15
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 43
Time Indication: 0
Date: 2011.10.18
Time: 19:04:03
Freeze Frame:
Mileage: 655350 km
Count: 1901
Clock: 20:08
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:09
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:09
02444 - Disk Drive Load / Eject Malfunction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 42
Time Indication: 0
Date: 2010.09.03
Time: 19:02:05
02005 - Coding Pin
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:19
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBDF54FF999E50C
No fault code found.
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309111
6 Faults Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Reset counter: 2
Time Indication: 0
Date: 2010.06.18
Time: 10:33:15
Freeze Frame:
Mileage: 655350 km
Count: 1007
Clock: 11:15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 43
Time Indication: 0
Date: 2011.10.18
Time: 19:04:03
Freeze Frame:
Mileage: 655350 km
Count: 1901
Clock: 20:08
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:09
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:09
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 42
Time Indication: 0
Date: 2010.09.03
Time: 19:02:05
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:19
End ---------------------------------------------------------------------
I have RNS-E but the disk will not read for the nav, I figured this was a lazer lens problem, could someone explain the above results to me please?
The RNSE plays the SD cards fine and the sound is great so I don't understand the speaker faults? could this just be a retro fit that needs coding properly?
Paul
C6 S6 completely standard car just imported with full history from Switzerland - Needs an exhaust!!
B6 S4 Misano Red, KW V3's, RS4 ARB's, Miltek
Rick_RS4
Re: First try of the Vag com
Post by Rick_RS4 » Sat Jan 21, 2012 11:37 pm
did you wipe all those and start again,?some faults could have been on there ages
wardy124
Post by wardy124 » Sun Jan 22, 2012 12:34 pm
I'll try wiping them,
I'm wondering if somethings given up on the RNSE?
TimDogg
Post by TimDogg » Mon Jan 23, 2012 6:56 pm
Mate, I retro-fitted the RNS-E and I get some of those faults - it's because the SatNav was not a factory fit. Not sure about the air sensor one though.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
Post by Shoppinit » Tue Jan 24, 2012 9:24 am
I got the airsensor one occasionally. I changed it. Don't get the error anymore. Simples. Not that you know when it's working anyway :(
Return to “DTC / VCDS”
