Hello All,
I have recently changed to an S4 and I have and issue.
The car is an 03 with 50k on it. Full service history etc.
When driven hard (eg redline) the engine becomes very rough through the rev range and vibration is felt through the car.
This happens in gear and out of gear wich eliminates the transmission.
If I turn the car off and (give it a rest) then start it again all is fine.
Iam fairl mechanically minded and however I can not for the life of me figure out what it is.
Engine vibration only after hard drive
Re: Engine vibration only after hard drive
Sounds like what happened to me when my flywheel was on the way out
Similar sort of mileage too
Edit to say could also be a coil pack
Dolphin Grey B6 S4 - 361PS - 474Nm
Flywheel is on it's way out ..
Unit 20
0151 3366888
0151 3366888
Coil packs sounds more likely as they have not been done !
- cobraBLACK
Is it misfiring?
Do you get a CEL light?
When it starts, is it OK on light acceleration but becomes more apparent the harder you accelerate?
Audi S4 Avant (B6, 2004) in Goodwood Green.
