Disconnect the RNS-E 6 CD changer, what will happen?
stu
Post by stu » Wed Dec 21, 2011 12:54 am
Hi, I never use the CD changer and a mate would like to put it in his own car. If I simply unplug it, will the RNS-E throw a wobbler and refuse to function? I'd rather not perform this surgery and end up with a non-operable radio/SD card player for the holidays :)
Sorry if it's a silly question, but I haven't a clue!
It's an RNS-E unit in a B7 RS4, with a TV tuner that I also never use and would be happy enough to get rid of too.
All advice much appreciated!
PetrolDave
Re: Disconnect the RNS-E 6 CD changer, what will happen?
Post by PetrolDave » Wed Dec 21, 2011 6:56 pm
stuwd wrote:If I simply unplug it, will the RNS-E throw a wobbler and refuse to function?
Nope, everything else will carry on working as normal.
The RNS-E will store a fault code but that won't stop anything else working.
sonny
Post by sonny » Wed Dec 21, 2011 7:39 pm
Iv had my CD changer unplugged now since I have owned my car, I had an ipod adaptor fitted when I purchased the car.
PetrolDave
Post by PetrolDave » Wed Dec 21, 2011 7:47 pm
sonny wrote:Iv had my CD changer unplugged now since I have owned my car, I had an ipod adaptor fitted when I purchased the car.
The iPod adapter plugs in where the CD changer goes - so your RNS-E still thinks there's a CD changer plugged in, which makes your experience not relevant to the question that stuwd is asking.
stu
Post by stu » Wed Dec 21, 2011 8:11 pm
Fantastic, thanks for the help. Stu.
sonny
Post by sonny » Wed Dec 21, 2011 11:09 pm
What car is it going in?
stu
Post by stu » Thu Dec 22, 2011 12:05 am
I don't even own a single CD, so It's going in someone else's B7 2.0 TFSI. It hasn't got RNS-E but my mate's confident it'll work ok. In exchange for some detailing :)
I'm planning on getting an aux in installed - it's only taken me a year! The drag is wondering how to get power into the glove box for a stereo A2DP receiver. I want to play my music over the iPhone but I really like the OEM cradle mounted on the central console. I might be sacrificing a little fidelity over A2DP but road noise cancels that out fairly well. I think I might have to piggy back onto the 12V cigarette lighter socket near the handbrake and snake a wire up and into the glove box. If the end socket is a cigar lighter it'll be fairly versitile for whatever A2DP device I find. Fingers crossed. I probably don't need to get rid of the CD changer but it's useless to me. As is the TV tuner - I haven't a clue who uses those things... :bash:
PJC
Post by PJC » Thu Dec 22, 2011 12:35 am
Hardly ever used mine, certainly won't have ticked that box when speccing the car, they are not cheap too.
PetrolDave
Post by PetrolDave » Thu Dec 22, 2011 6:30 pm
stuwd wrote:I'm planning on getting an aux in installed
If you have an RNS-E then the Aux In is completely separate to the CD changer/iPod connection.
If you code the RNS-E to 0xxxx5x that will enable a separate audio Aux In (see http://wiki.ross-tech.com/wiki/index.ph ... 28RNS-E%29 ), and then you can buy a cable from Kufatec http://www.kufatec.de/shop/product_info ... RNS-E.html which will give you an Aux In connection. Connect an A2DP adapter to that and you're done.
stu
Post by stu » Thu Dec 22, 2011 6:52 pm
PetrolDave wrote: and then you can buy a cable from Kufatec http://www.kufatec.de/shop/product_info ... RNS-E.html
Good stuff - that was the cable I was looking at last night and was fairly sure it was the one. :beerchug:
Post by HYFR » Thu Dec 22, 2011 11:02 pm
only just found out my R8 has an 3.5mm Aux In built in from the factory
stu
Post by stu » Thu Dec 22, 2011 11:19 pm
aka_dk wrote:only just found out my R8 has an 3.5mm Aux In built in from the factory
They're very handy things - even handier if they're out of sight. I don't like memory cards and expensive proprietary systems like iTunes/iPods and so on that lock you in. A 3.5mm aux in is universal - you can plug in the next new sound technology as soon as it comes along.
I'm getting my bumper droop fixed in the morning at Revolution so I'll ask them to code the RNS-E ready for the aux.
PetrolDave
Post by PetrolDave » Fri Dec 23, 2011 9:52 am
It was introduced onto the R8, TT and A3 in about November 2009 - but with zero publicity.
Post by HYFR » Fri Dec 23, 2011 1:33 pm
not got it in my TTRS ?
PetrolDave
Post by PetrolDave » Fri Dec 23, 2011 1:57 pm
aka_dk wrote:not got it in my TTRS ?
You've been had - it became part of the standard spec of all Audis fitted with either RNS-E or Symphony II+ in late 2009.
Return to “Electrical”
