Tyre Pressure Warning
djt
Post by djt » Sun Dec 18, 2011 6:57 pm
Just had my tyre pressure warning light come on, so I nipped to the garage and pumped all 4 tyres up but the warning is still showing.
Any ideas???
adsgreen
Re: Tyre Pressure Warning
Post by adsgreen » Sun Dec 18, 2011 7:09 pm
Reset the pressures and see what happens.
djt
Post by djt » Sun Dec 18, 2011 7:10 pm
adsgreen wrote:Reset the pressures and see what happens.
OK.... Erm... How? :oops:
adsgreen
Post by adsgreen » Sun Dec 18, 2011 7:12 pm
In the dis menu - should be a 'set pressure' or similar
PetrolDave
Post by PetrolDave » Sun Dec 18, 2011 7:24 pm
BTW for those who have been saying that the MOT test will start testing TPMS systems from 1st January 2012 see page 105 of the MOT Inspection Manual here http://www.dft.gov.uk/vosa/repository/M ... Manual.pdf
MOT Testing Manual wrote:The inspection of the tyre pressure monitoring system (TPMS) warning lamp only applies to passenger vehicles with:
- four or more wheels, and
- not more than 8 passenger seats excluding the driver’s seat, and
- first used on or after 1 January 2012
So the TPMS on a B7 RS4 will NOT be part of next years's MOT test - since they have been first used before 1 January 2012.
Gazzaton
Post by Gazzaton » Mon Dec 19, 2011 3:44 am
Also had tyre pressure warning light on when I picked my RS4 a few weeks ago, guy said it was because he'd had 20inch wheels on it while he had the originals in the Shop getting refurbed, said it would sort itself out after a while. Waited a week then tried setting the tyre pressures as per the chart on the door jam and then got red warning saying pressure too low. Tried putting pressures back up but red warning still on and won't let you go into the menu to set the pressures????
'57 Avant, Black with black optics pack, milltek resonated and valved, 200 cell high-flow cats, de-vaned port n polished manifold, stage 2 remap, Revolution carbon-fibre induction kit
sumdy
Post by sumdy » Mon Dec 19, 2011 11:04 am
You will get into the dis menu if you do not start the engine but just turn on the ignition.
Gazzaton
Post by Gazzaton » Mon Dec 19, 2011 11:23 am
Thanks sumdy, will try that when I get home, weather permitting
ShouldveBeenAGerman
Post by ShouldveBeenAGerman » Mon Dec 19, 2011 2:26 pm
Is there a way to disable to TPMS completely? Via Vagcom maybe?
adsgreen
Post by adsgreen » Mon Dec 19, 2011 5:14 pm
Yes - Vagcom can disable it.
psg001
Post by psg001 » Mon Dec 19, 2011 8:19 pm
sumdy wrote:You will get into the dis menu if you do not start the engine but just turn on the ignition.
That bloody worked, fantastic. Had been stuck with the annoying warning sign since tyres changed about a month ago!!!
Daytona Grey TT RS coupe - Stage 1 400bhp+ :D
Misano Red B7 RS4 Saloon (black optics) Milltek Non-Resonated Valved Exhaust SOLD
Users browsing this forum: No registered users and 223 guests
