KW3's or PSS9's for an RS4 B7 Cab, thoughts???
RS4shaw
Post by RS4shaw » Mon Oct 31, 2011 11:16 pm
Undecided on which to go for, comments welcome. ;)
ShaneyB
Re: KW3's or PSS9's for an RS4 B7 Cab, thoughts???
Post by ShaneyB » Mon Oct 31, 2011 11:20 pm
Look forward to replies as looking at the same thing.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
sonny
Post by sonny » Tue Nov 01, 2011 12:49 am
I can only comment on the KwV3, iv had them on there car now for well over 2 half years and they gave been great! Those that have been in my car would probably agree also.
m5killer
Post by m5killer » Wed Nov 02, 2011 9:08 am
ive got kw3 on my cab....very good stuff.....a few notches above the pss9s without a doubt....kw all the way :beerchug:
JackS4
Post by JackS4 » Wed Nov 02, 2011 11:07 am
I have PSS9's and they are good but remember to uprate your ARB's at the same time. The KWs are probably a better technical answer with regard to optimising settings but PSS9's are probably easier to change the settings on (takes a couple of minutes to do all 4) and fool proof when it comes to not messing the settings up (as I seem to do with ease on Gran Turismo with too many parameter to play with).
J
adsgreen
Post by adsgreen » Wed Nov 02, 2011 1:19 pm
JackS4 wrote:I have PSS9's and they are good but remember to uprate your ARB's at the same time. The KWs are probably a better technical answer with regard to optimising settings but PSS9's are probably easier to change the settings on (takes a couple of minutes to do all 4) and fool proof when it comes to not messing the settings up (as I seem to do with ease on Gran Turismo with too many parameter to play with).
J
Damn right! - When I first got let loose with my track car and 4 way fully adjustable everything I found it all too easy to end up with a mess and restoring the factory settings took ages! (lots of click counting and all too easy to loose track!)
stu
Post by stu » Fri Nov 04, 2011 1:55 pm
Do KWs and PSS9s need continual tweaking or can they be set up and forgot about for ever after?
Is there a cheat sheet with generally accepted settings for the avant, cab and saloon for lesser mortals?
I'm not in the market btw, just curious.
JackS4
Post by JackS4 » Fri Nov 04, 2011 2:02 pm
Can't speak for KWs but PSS9s are pretty much fire and forget but dead easy to adjust if you fancy a change/go on track etc. Reverting back to what you previously had is only as challenging remembering what number (1 to 9) you previously had them on and taking the 2minutes to change them.
J
sonny
Post by sonny » Sat Nov 05, 2011 9:47 pm
When I had the KWv3s set up by MRC, I wanted a medium contrast. so they set them at 7 bound, 8 rebound and medium ride. Iv not touched them since, and iv been running them for 2 years now.
Rick_RS4
Post by Rick_RS4 » Sun Nov 06, 2011 11:12 am
think im going to go with the ASTs, read good reviews from them, had problems with shocks bursting on KW in the past (i did ride low though)
sonny
Post by sonny » Sun Nov 06, 2011 11:27 am
The competition or the Sportline Rick?
Users browsing this forum: Majestic-12 [Bot] and 203 guests
