Odd search anomaly
Odd search anomaly
I made a thread called "RS6 useful info and links" in the C5 RS6 section. When I need to find it, I use the advanced search function and search for "useful" because I always remember that that word is in the title. However, this brings up ZERO matches. Yet when I search for "info" it finds it straight away.
Any particular reason?
- Steve_C
- Top Gear
Re: Odd search anomaly
Sounds like the search function isn't particularly 'useful'!
Gone to the dark side
This is a test to see if this word is in the search - Grandiloquent
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Grandiloquent works, but useful does not.... HmmmmPhilT wrote:This is a test to see if this word is in the search - Grandiloquent
| Ultima Evolution
OK, so it seems that other phpBB powered sites have the same problem, but phpBB.com does not.
I fear this is a bug and that I may need to do an upgrade.
| Ultima Evolution
Maybe it's on a list of excluded words like "the" or "a".
Call it a "feature"
Call it a "feature"
Maybe, but I don't see where that list would be. Here are the settings for our indexing backend.
Fulltext mysql
Support for non-latin UTF-8 characters using PCRE:
This search backend requires PCRE unicode character properties, only available in PHP 4.4, 5.1 and above, if you want to search for non-latin characters.
Yes
Support for non-latin UTF-8 characters using mbstring:
If PCRE does not have unicode character properties, the search backend will try to use mbstring’s regular expression engine.
Yes
Min characters indexed by search:
Words with at least this many characters will be indexed for searching. You or your host can only change this setting by changing the mysql configuration.
2
Max characters indexed by search:
Words with no more than this many characters will be indexed for searching. You or your host can only change this setting by changing the mysql configuration.
84
| Ultima Evolution
There's always a 'noise' word dictionary. Have you tested with a wildcard search? e.g. use* or usef*
EDIT: It's like that thread hasn't been indexed!?
Re: Re: Odd search anomaly
Thanks bam.bam_bam wrote:There's always a 'noise' word dictionary. Have you tested with a wildcard search? e.g. use* or usef*
Noise word dictionary? I guess I need to educate myself on that one.
Use* works.
| Ultima Evolution
Use* works but it misses that thread, however it hits misspellings of useful (such as usefull). It looks like "useful" may have snuck into the noise word dictionary, seems really odd though! For example, search for usef* right now and you SHOULD hit this post, it won't happen. The noise word dictionary can also be referred to as a noise word filter, but, to be honest I've also seen it called some stupid names... anything to make life harder.
EDIT: Hmmmm, now it works or I missed it...
TEST
