Have i missed anything?
bilko1
Post by bilko1 » Mon Aug 29, 2011 3:03 pm
My car is being shipped off to Grizz for a recon gearbox and the ACE torque converter to be fitted, while the engine is out i thought i'd get all the niggles sorted out plus a few extras.
I've got timing chains and tensioners (the rattle annoys me) Cambelt including all rollers tensioners etc, waterpump and thermostat, cam cover gaskets, Pre-cat O2 sensors and exhaust gas temp sensors. Hopefully this lot will keep me going for a few years. Have i missed anything?
Rupert
Re: Have i missed anything?
Post by Rupert » Mon Aug 29, 2011 3:32 pm
Be sure to keep up updated, I'd love to know how this goes.
mavada
Post by mavada » Mon Aug 29, 2011 3:36 pm
Maybe bigger turbos now you have an ace tc... :biggrin3:
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
bilko1
Post by bilko1 » Mon Aug 29, 2011 3:57 pm
mavada wrote:Maybe bigger turbos now you have an ace tc... :biggrin3:
I probably could have got some Lobas for the price of this lot :beerchug:
posterboyj
Post by posterboyj » Mon Aug 29, 2011 4:41 pm
Excellent! Good luck!
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
posterboyj
Post by posterboyj » Mon Aug 29, 2011 4:44 pm
Instead of loba, you could "hybrid " your current turbo?
Port manifolds
3" down pipes
Bigger injectors
Post by Shoppinit » Tue Aug 30, 2011 9:29 am
I'm sure grizz will advise, but I'm sure there are some crank oil seals that are prone to leaking. Easy to do when the engine is out.
You could always have yuor turbos remanufactured. Not terribly expensive and buys you peace of mind. Especially if you have been on stock intercoolers and not been leak detecting regularly. Or loba :)
If you are going catless are you having the downstream lambda sensors mapped out?
Uprated valve body?
There's plastic a tube in the oil cooler that is prone to leaking coolant. It's a biatch to get to. Would be much easier with the engine out.
Change your V51 circulation pump while the inlet manifold is off. It's a cheap part and could save your turbos since it fails often and discretely.
bilko1
Post by bilko1 » Tue Aug 30, 2011 12:08 pm
Thanks Shoppinit :bigwave: i'm having the post cat O2 sensors mapped out :bigblink: I did think about getting the front and rear crank seals but i'll let Grizz sort them as my TPS had enough trouble finding the EGT sensors and some other parts, i had to get them the part numbers :nodder: I'll tell Grizz to check / replace the oil cooler pipe and i think i could manage the V51 pump if need be.
chesney
Post by chesney » Wed Aug 31, 2011 7:24 pm
All sounds great, good to see you looking after her! Did the box go pop???
bilko1
Post by bilko1 » Wed Aug 31, 2011 8:40 pm
chesney wrote:All sounds great, good to see you looking after her! Did the box go pop???
No, got the dreaded torque converter stuck off code so getting it sorted before it takes box out and contamiates everything.
chesney
Post by chesney » Wed Aug 31, 2011 9:16 pm
not so bad and def good idea to put something stronger in there :thumbs:
bilko1
Post by bilko1 » Wed Aug 31, 2011 9:44 pm
chesney wrote:not so bad and def good idea to put something stronger in there :thumbs:
You still driving BMW's ?
chesney
Post by chesney » Wed Aug 31, 2011 9:52 pm
Yeah still got the 335i. Been playing with it and its fun but I miss the 4wd traction cos this thing just can't get the power down as soon as it rains. Even loses traction at 70 in the dry if you are too aggressive....here's why LOL!! This was before I fitted decat pipes (to help save the turbo's).
bilko1
Post by bilko1 » Mon Oct 24, 2011 11:49 pm
Big thanks to Grizz, Lee and Rhian for getting my car sorted :beerchug: Poor Lee and Grizz had the engine out 3 times due to a leaking turbo feed pipe :drink: Purrs like a cat idling and roars like a lion when the loud pedal is pressed :bigblink: and no more strange gearbox behaviour :jump_clap: Managed 24 mpg on the 275 mile trip home, not bad considering the 7 mile tailbacks on the M56 and me playing with the loud pedal and grinning like a cheshire cat most the way :bigblink:
Keaney
Post by Keaney » Tue Oct 25, 2011 12:21 am
Good stuff! I'd be keen to know how the ace tc goes and if it's the best choice if the gearbox goes.
Did you order it online?
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Users browsing this forum: Majestic-12 [Bot] and 219 guests
