I was putting air into my tyre and the metal part of the valve snapped off and have been told I need to get the whole lot which comes with sensor
B7 tyre pressure sensors
Does anyone know the best place to get a tyre pressure monitor from apart from the Audi Stealers ?
Re: B7 tyre pressure sensors
crap - my dealer broke a valve when swapping a tyre and they said it can be replaced (which they did) for a tenner.
They advised that it's common and warned me up front as they corrode and break easily.
- Steve_C
- Top Gear
I replaced two valves recently (due to corrosion). They were about £12 each from TPS.
Gone to the dark side
Thanks guys, so you can replace the outer valve without replacing the sensor inside I take it ?
Yes you can,tyre off remove old valve fit new one(£13 from audi)
ok, thanks
Users browsing this forum: No registered users and 534 guests
