A Query for those technical out there
P_G
Post by P_G » Fri Aug 12, 2011 3:03 pm
Unfortunately I have experienced my first major problem with the RS today in 4 years on ownership. Took it out today for a run at lunchtime as it hadn't been used since Monday and when warming up felt a slight misfire but went as the revs invcreased. Drove for another 20 or so miles with no issues through the entire rev range but then had to stop for petrol.
After starting up again I drove down to the first roundabout and the engine cut out. Odd. So started up again and coasting at low revs the engine cuts again. Then starting it the third time and there is a distinct misfire and it progressively gets worse. Pull over to do a VCDS scan on the car and sure enough multiple misfires detected code and then lists cylinder 1 and 5. Decide that since I'm only a mile or so away from Tyneside Audi I'll take it there misfiring away and cutting out every time under 1500rpm i.e coming to a junction. When I get there it cuts out again and another scan shows misfires on cylinders 5,1 3 and 2 and the IM runner flaps are both implausible signals. Start it up again and it is misfiring horribly and hunting for 10-15 seconds or so at idle and then cuts out. Of course EML flashing and EPC on
So it is now sitting at Tyneside awaiting inspection.
Any ideas? Could damaged lambda sensors cause such misfiring. I only ask as I cleaned the full underside of the car at the weekend with a pressure washer except of course the engine bay.
Doug_S2
Trader (Expired)
Re: A Query for those technical out there
Post by Doug_S2 » Fri Aug 12, 2011 3:38 pm
Sounds like a vacuum leak off the inlet manifold so it sucks in too much air and cannot make it idle.
http://www.MRCtuning.com
sonny
Post by sonny » Fri Aug 12, 2011 3:46 pm
Hope its a easy and simple fix.
P_G
Post by P_G » Fri Aug 12, 2011 3:50 pm
Would that cause misfiring as well Doug?
The codes were;
Right Engine Solenoid Valve (N145): Open Circuit
P1577 - 004 - No signal / communication - Intermittent
000768 - Random / Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
000769 - Cylinder 1: Misfire detected
P0301 - 001 - Upper Limit Exceeded
That was the first scan, I didn't get a chance to log the second scan.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Fri Aug 12, 2011 3:58 pm
it would cause misfires as well
P_G
Post by P_G » Fri Aug 12, 2011 4:05 pm
Thanks, let's see what the masterminds at Audi come up with.....
RSKiwi
Post by RSKiwi » Fri Aug 12, 2011 4:25 pm
P_G wrote:Thanks, let's see what the masterminds at Audi come up with.....
My money is on
'No problem sir we have changed your washer fluid and rear wheel TPMS sensor its all fixed' ....followed by cheesy grin and their hand out for £923.36
Youd drive out the gate with the car in exactly the same shape as when it went in.....
Spot the person who has been burnt by Audi before?!!
:D
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
P_G
Post by P_G » Fri Aug 12, 2011 4:29 pm
They know me better than to do that, I must be one of their 'loyal but pain in the ass' customers. :biggrin3:
Timster
Post by Timster » Fri Aug 12, 2011 4:53 pm
My money is on
:D
lol... yeah. I bet the first time you come to use the washers... they're empty !
Revolution
Trader (Expired)
Post by Revolution » Fri Aug 12, 2011 5:18 pm
any news on what it is......?
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
P_G
Post by P_G » Fri Aug 12, 2011 5:26 pm
My source on the inside says the master techs are looking at it now.
Revolution
Trader (Expired)
Post by Revolution » Fri Aug 12, 2011 5:31 pm
fingers crossed for you...
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Revolution
Trader (Expired)
Post by Revolution » Fri Aug 12, 2011 5:39 pm
Have you heard anything yet?
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
adsgreen
Post by adsgreen » Fri Aug 12, 2011 5:42 pm
Agree with doug on this.
I did some vacuum system testing as per the tech bulletin. Once finished I just started the car (as opposed to ignition key out) so for a split second there was no vacuum.
By god did the car complain - multiple misfires, manifold flap codes, flashing MIL and EPC lights on.
I shut off the car (after a big "oh feck I've broken it" moment) double checked the connections I'd used to manually test, and then restarted from cold after clearing all the fault codes. Everything back to normal and never troubled me again.
So yes, does sound like the connection/valve under the inlet manifold has gone or there is some other big vac loss somewhere . However as per the TSB you can test this without taking the manifold off - just disconnect or T the various vac lines and see what pressure it attains and what it's holding. Even easier if you use a hand vacuum pump to test. Shouldn't be no more than an hour (probably less) to diagnose if the IM has to come off.
P_G
Post by P_G » Fri Aug 12, 2011 5:51 pm
Hopefully Audi's mastertechs are as insightful. Just seems odd that after a good few weeks it catastrophically lets go like that?
Users browsing this forum: No registered users and 180 guests
