My driver side headlight has a small crack in the top edge, you cant see it when the bonnet is shut but its letting in a small amount of water and causing the light to fog up.
Does anyone know if its possible to replace the clear lens?
Headlight Lens Replacement?
Re: Headlight Lens Replacement?
Unfortunately no it isn't... you would have to replace the complete light cluster!
Or seal the crack with some clear silicone & the moisture inside will soon dry out ?
I had a bike with a crack across the headlight sealed with silcone & it passed multiple MOTs & didn't get any condensation etc. in so am sure would be OK especially if can't see it when bonnet is closed.
