I've had this horrible noise when going over medium-sized bumps in the S4 recently.
I had it in the garage on Friday and they could hear the noise but struggled to find the source.
The only thing they could find was that the nearside front brake pad sits a little loose - but there's nothing wrong with it. No idea what make they are (probably OEM)
Has anyone had this problem and solved it?
Rattling Brake Pads
- cobraBLACK
Rattling Brake Pads
Audi S4 Avant (B6, 2004) in Goodwood Green.
- cobraBLACK
Re: Rattling Brake Pads
I saw. Thanks, Lee.leewhiteheadmma wrote:I have, replied to your post on Audi SRS
sorry guys - i'm not on SRS.. what was the answer?biyitch wrote:I saw. Thanks, Lee.leewhiteheadmma wrote:I have, replied to your post on Audi SRS
Ta
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
- cobraBLACK
Get yaself over there then, sunshine!
He said:
He said:
leewhiteheadmma wrote:I had the same thing, with the pads I got from Mtec when I changed the discs, took it to fast fit and had OEM brake pads put on, solved.
it appears the pads were slightly smaller on the ones they sent me and the rattled in the calipers.
took ages to find
