Avus Rs4 with 509hp and 554lbs/torque
juice
Post by juice » Sun Jun 05, 2011 2:23 pm
I am so going to regret doing this and im still unsure but here goes after nearly 2 years of ownership and empty pockets I am selling my pride and joy. I have enjoyed ownership of this amazing car but I’m afraid the toys are going to have to go on the back foot for a little while. Some of you are aware that I intend to get married and hopefully look into a property so for the time being I wont require the Rs, but can guarantee that I will be back In the future as its seriously the best car I’ve owned to date, therefore this one needs to go.
The car is completely unique and just to give you an idea of the cars power I have two maps for the car – Its currently running a pretty safe map for my day to day driving (Map 1) which is 516PS! With 751NM of torque! Yes…That’s right this car does not stick around, with this map the car peaks 27psi and tails down to about 24psi! Please note I do not own a petrol station therefore do not drive around like I’ve stolen my car. This map is the one that will give the most smiles, shove you and your passenger in your seats and destroy pretty much anything on the street.
(Map 2) is 525PS! With 666NM torque – this map has reduced boost to 20-21 psi with adjusted timing and is suited for when you want to take it on the track as less strain and heat will be put on the engine as you’ll most likely be high up in the revs for longer periods of time.
Both maps are from MRC TUNING and can be selected from a discreet switch (based in Banbury, Oxford) should you want more info on this Doug is the best person to speak to.
As far as I know this is one of the quickest cars they have tuned on Ko4 turbos!
I have dyno plots for every stage that the car has gone through, however cannot express to you the power delivery on the car, its so bloody fast that when the Intake air temperatures were 4 degrees at MRC Tuning (4th December 2010 Rolling Road event) the car made 544PS!
Should you want more power you really just need to upgrade the turbos to Rs6 items and upgrade the clutch and you should see near 600PS? You probably aware that standard cars produce 380PS so this one is in another league
The interior is in A1 condition. The car has carbon Trim with Black leather seats which are treated regularly to liquid leather cleaner/conditioner. The car also has privacy glass fitted which stops unwanted attention. The roof is also vinyl wrapped in a textured carbon print which was done from Totally dynamic in Enfield (can be removed should it not suit your taste)
I have a folder of receipts adding into Thousands of pounds!! on maintenance from oils to modifications/parts and labour charges. The car has been my pride and joy and so has been maintained at any expense. You seriously do not want to skimp on these cars, when I was looking into buying an Rs4 I only wanted to buy from an enthusiast purely because they would have treated the car the same way I would treat a specialist vehicle.
The previous owner had bought it at 72K miles and passed it on to me 3 ½ years later at 114K miles and now the present mileage is 130K. Please do not think for one minute this is a bad thing, mileage purely shows how much it has been used but the car drives like its covered half that, practically every part that has need to be fixed has been replaced to the same spec or better.
The majority of the modifications and the major servicing have been carried out by MRC Tuning recognised as one of the leading specialists for these exclusive cars and Virdee Autos (London, Park Royal). Please speak with them should you want to verify.
You will be glad to know that in March 2011 the camshafts were checked at MRC Tuning and have been given the all clear to wear so about 2.5K saved there already on costs that you may think you might have to anticipate. I have pictures to prove should you want to see. For the mileage they are the best condition I have seen comparing to other members.
The cambelt has been replaced with water pump, thermostat and tensioners etc at 114,500 miles with Bosch spark plugs by MDM Teknik.
The MAF, EGT sensors, one way valves (on top of the engine), N75 valve and coolant temperature sensor, rubber intake hoses that connect to the y-pipe have all been replaced in my ownership. The car also benefits from having a New Bosch battery, Alternator, Clutch, and Steering rack fitted in the last 25K miles all from MRC. Goodyear F1 Asymmetrical tyres fitted from Elite Tyres in Essex and covered approx 5K miles so loads more life left.
The oil is changed every 3K miles and has just had one at Virdee autos using Gulf competition oil. The vehicle Geometry has also been set up to fast road use. The oil cooler pipe which usually corrodes really badly has been replaced by MRC at 118K miles and shortly after at 122K miles Bosch spark plugs and a OEM Fuel filter was replaced at MRC.
All four wheel bearings have also been replaced with oem parts by Virdee so another issue you wont have to worry about
Taxed till February 2012 and MOT till October 2011. I will also include in the sale price the private RS registration which has a comical meaning to those who get it. The Rs4 is a March 2001 car so benefits from the cheaper tax bracket, 225 for the year. Always warmed up and cooled down properly and if anything has ever needed to be replaced it has to the same spec or better. HPI clear
Spec:
Avus Silver (will be shown as purple in the V5 like all other Avus silver rs4’s)
Black Recaro Leather electric seats (heated)
Carbon Trim
Hard wheels (replaced from soft ones by Audi)
Front and side airbags (passenger side can be disabled via a lock in the glove box)
Alarm / immobiliser + Tracker and anti hi jack (more on that later)
Cruise control
Electric windows
Climate control
Electrically heated and adjustable mirrors
Headlight washers
Front and rear headrests
Heated windscreen nozzles and locks
Leather steering wheel
Split folding rear seats
Ski hatch through rear seats
Retractable rear load cover
Retractable rear luggage net
Xenon headlights
Front centre armrest
Load securing net
Satellite Navigation Plus system and integrated TV receiver
Engine Mods:
Wagner upgraded side mount intercoolers with Carbon fibre shrouds and front metal grills
Full Miltek Exhaust system with 3inch downpipes
Silicone hose to replace OEM accordion hose.
MRC ITG panel filter with modified air box
Welded intercooler charge pipes to throttle body (most boost leaks tend to happen hear so this is the permanent solution)
Water / Methanol Injection (extra cooling = more power for longer) – kicks in after 15psi
MRC dual map
Bosch 044 5 bar fuel pump
Bosch 710n’s
AWE boost gauge in centre vent
Brakes:
RS4 b7 8 Pot Brembo callipers with 365mm VW Phaeton discs with Pagid pads (discs and pads covered 1K and fitted by Virdee Autos)
Rear OEM discs with new brake pads fitted in the last 3K miles (Virdee autos)
VW Phaeton front brake cooling ducts
Braided lines front and rear (supply and fit from MRC)
Motul RBF600 Brake fluid (recently flushed – MRC)
Suspension:
Bearing in mind that the mileage is 130K I had the dampers replaced with items that had covered 60K miles bought from MRC and these were installed at 120K miles on my car, so technically the suspension as covered 70K
H&R lowering springs (40mm)
Front H&R thick anti – roll bar
Rear H&R thick anti – roll bar with MRC strengthening brackets (prevent rear subframe from cracking)
Drive train:
Quick shifter
ESP heavy weighted gear knob (makes massive difference)
AWE drive train stabiliser
Gearbox and diff oils changed 15K ago with Silkoline oil products at MRC
ESP spacers – Front 10mm and Rear 15mm with longer nuts
Ice:
I pod connection
TV tuner works while on the move
Front door speakers replaced with Infinity reference items.
Rear Bose speakers
20GB Phatnoise (currently disconnected)
Parrot Bluetooth kit
Origin b2 speed detector and laser jammer
Security:
Smoked window tints
Upgraded Clifford Avant-garde alarm with anti hi jack (black jack), proximity sensor, motion senor, and anti lift sensor – This sits on top of the OEM alarm effectively giving the car 2 alarms. When I purchased the car I was aware of scum that we live with in society and wanted to protect my pride and joy therefore for my peace of mind had this fitted, I will only show how this works once the car is sold – Potential genuine buyers please understand why.
Only downside I can think of is the 2 stone chips on the front, nothing seriously bad.
More pictures can be emailed on request
The car is a AudiSRS car and can be vouched for by members and sponsors.
Timewasters/Test pilots/Dreamers need not apply and a test drive will ONLY be considered if you hold full insurance otherwise I’ll be doing the driving.
Thanks for looking
16,750 GBP
ps: negative comments need not apply. More pictures to follow
http://audisrs.com/about9801.html the link gives you an idea of hows it come along
Avus B5 RS4, Miltek down pipes/No cats/Miltek Cat-back, Wagner uprated SMIC's, short shifter, B7 brakes, Phaeton brake ducts, H&R ARB's, H&R Coilovers, AWE DTS, MRC custom Remap + water meth injection = BIG GRIN on my face with poo in my passengers pants
**Now with a Carbon roof**
'Build the best and the rest will follow'
RS6Steve
Re: Avus Rs4 with 509hp and 554lbs/torque
Post by RS6Steve » Sun Jun 05, 2011 4:26 pm
No way... I never thought this day would come. This is a really nice car you have, hopefully it will find another nice home.
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
juice
Post by juice » Sun Jun 05, 2011 4:27 pm
heres the plot from december when it was 7 degrees :shock: :shock: :FIREdevil:
my most recent plot is half way down in this thread
http://audisrs.com/about22990.html
:boohoo:
MoRS6+
Post by MoRS6+ » Sun Jun 05, 2011 6:16 pm
RS6Steve wrote:No way... I never thought this day would come. This is a really nice car you have, hopefully it will find another nice home.
+1, epic car..
Someone is gonna get one of the best RS4s out there right now for sure.
GLWS matey, hope it goes to a good home. :thumbs:
Steve_C
Post by Steve_C » Sun Jun 05, 2011 8:14 pm
GLWS - looks like an awesome car. And I like the photo above with the colours of the graffiti!
Gone to the dark side
dunk5y
Post by dunk5y » Sun Jun 05, 2011 8:42 pm
Heart was all set on a RS6 this has certainly made my head turn :thumbs: a credit to yourself and preious owners, cannot wait to see more photos.
Dunk
juice
Post by juice » Sun Jun 05, 2011 10:00 pm
thanks for all the kind words
heres a few pics from my collection
more available upon request
ShaneyB
Post by ShaneyB » Mon Jun 06, 2011 5:11 pm
Juice,
You were at Ace on Sunday night right?
Car looked lush!
Good luck with the sale.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
juice
Post by juice » Mon Jun 06, 2011 11:25 pm
Yes shane, i did come over for a little while but couldnt put usernames to faces
ended up leaving early as it was rubbish weather.
the drive home was nice! my passenger has never been in an rs4 b5 before and he was loving the power delivery :kissmyrings:
sonny
Post by sonny » Tue Jun 07, 2011 12:23 am
Wow...fantastic sales pitch there Saq, car is indeed immense. This car looks fantastic in the flesh!
GLWS mate.
p.s thanks for the pads ;)
RS4KILLA
Post by RS4KILLA » Tue Jun 07, 2011 10:37 am
good luck with sale sak
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
juice
Post by juice » Wed Jun 15, 2011 7:23 pm
bump
juice
Post by juice » Wed Jun 29, 2011 5:55 pm
:boohoo:
Bump
iR8V10
Post by iR8V10 » Wed Jun 29, 2011 6:14 pm
Stick with it saq, it's a quality car, you just have to be patient!
S14
Post by S14 » Wed Jun 29, 2011 11:34 pm
Superb advert and a credit to its owner..
Out of interest do you know what the 1/4 mile times are in it?
Users browsing this forum: No registered users and 176 guests
