Cleaning Metal Trim
Cleaning Metal Trim
Can someone tell me the best thing for the external metal trims on the windows etc, i don't want to use the wrong product and damage them
Re: Cleaning Metal Trim
WD40 brings them up a treat
950 nm torque!
Ohh running bridgestones because they are the best
Great stuff, Thanks!
Any other ideas? If we're talking about the matt chrome RS strips I've tried WD40 and Autosol Liquid Chrome Cleaner which I also saw recommended and I just can't get rid of what looks like old wax spots on the strips around the window and ingrained dirty around the bottom of the boot and just under the bonnet?
B7 RS4 Daytona Grey Saloon
Optimum Metal Polish
I use Klasse All-in-One
it's a chemical cleaner, shines and protects
ShouldveBeenAGerman
Aren't these plastic on the window surround and boot??stefano wrote:Any other ideas? If we're talking about the matt chrome RS strips I've tried WD40 and Autosol Liquid Chrome Cleaner which I also saw recommended and I just can't get rid of what looks like old wax spots on the strips around the window and ingrained dirty around the bottom of the boot and just under the bonnet?
ShouldveBeenAGerman wrote:Aren't these plastic on the window surround and boot??stefano wrote:Any other ideas? If we're talking about the matt chrome RS strips I've tried WD40 and Autosol Liquid Chrome Cleaner which I also saw recommended and I just can't get rid of what looks like old wax spots on the strips around the window and ingrained dirty around the bottom of the boot and just under the bonnet?
the grill is, not sure about the window/trunk lip
are the mirrors metal?
either way they are painted, and should be treated as a painted surface...no harsh chemicals, abrasives, polish, etc.
basically clean and wax...
I do not think you will ever remove those spots once they are there it is like a water stain on a piece of furniture.
I've never let mine get too bad, and the piece that gets them the most (the trunk lip) is easily cleaned up with the KlasseTerry1948 wrote:I do not think you will ever remove those spots once they are there it is like a water stain on a piece of furniture.
it gets the usually spotting, and it does look like water spots, but applying the Klasse, rubbing it in, letting it sit for a minute, then wiping with a clean rag brings it back to almost new...
Just make sure you dont use one of those metal polish pastes, as they are abrasive and will scratch ali coating. Some owners have actually polish the Ali off and revealed the shiny metal underneath.
The window surrounds is metal.
Found out by mistake today. Autoglym super resin polish. Took off all the milky top layer and left it as new. And has anyone not got SRP?
xyber wrote:Found out by mistake today. Autoglym super resin polish. Took off all the milky top layer and left it as new. And has anyone not got SRP?
just looked at their website, pretty much the same stuff as Klasse All in One
Klasse All-In-One quickly polishes away oxidation and light paint contamination leaving a deep, rich shine that lasts for months. All-In-One is like clear armor for your car. It bonds to the surface like a normal carnauba car wax, however, it does not change the paint in any way. Klasse layers on top of the paint, building depth of shine and clarity for an ultra high gloss finish.
All-In-One contains special cleaners and a fine polish that quickly and easily removes old wax, road film, light oxidation and minor swirl marks. It’s a premium one-step product that cleans, polishes and protects with very little effort. Best of all, the finish lasts and lasts. In most cases, two applications a year will keep your car protected and looking good. Plus, Klasse does not contain silicones and it will not stain your car's vinyl and rubber. Application could not be easier!
Internationally acclaimed, Autoglym Super Resin Polish is the ultimate easy to use combination cleaner, polish and sealant. Ideal for all types and colours of new or moderately deteriorated vehicle paintwork, including metallic, clearcoat and waterbased paint finishes.
ShouldveBeenAGerman
Any pics mate?xyber wrote:Found out by mistake today. Autoglym super resin polish. Took off all the milky top layer and left it as new. And has anyone not got SRP?
