Dear All
Proceeded to upgrade my RNS-D to RNS-E. After much research and mostly down to the fine instructions posted by CRAIGYB on most audi forums, I made a start. Got all the cables from Kufatec, etc and know how to rewire the TMC box in the boot but hit one snag. There is a plug on the back of the RNS-D with 26 pins which is the AMP Connector. On the RNS-E its a 32 pin plug.
Didn't get an adaptor as part of the Kufatec kit so bit confused as what I need to do now. Is there an adaptor available. Did Kufatec snd me the wrong cables?
Any help would be gratfully received.
All the best.
Paul
RNS-D to RNS-E (Quick Question)
Re: RNS-D to RNS-E (Quick Question)
I don't know which kit you ordered. But it should have the 26 pin connector. This is the one I used when I upgraded from RNS-D to RNS-E:
http://www.kufatec.de/shop/product_info ... -Audi.html
If it is the same, did you check that you selected the right options (the same reference is used also for BNS navi adapter...) ?
Hi,
Thanks for the advice. Checked with my order and they have sent me the wrong cables so the correcvt ones are on the way.
Thanks again.
Paul.
Thanks again.
Paul.
