After the new shocks, car is higher at front
Hozz
Post by Hozz » Fri Apr 22, 2011 4:40 pm
After picking up my car from the dealers yesterday I thought the front of the car looked higher over the wheels than the rear and if I am honest it looks so awful I can't imagine that it used to be like that (unless DRC paranoia is taking over).
I wasn't very scientific but I parked up on level ground and could fit one finger between the underside of the rear wheel arch and the top of the tyre whereas the result at the front was two fingers.
The dealer replaced the two front shocks, suspension pipes and both accumulators but is it normal for the car to sit nose up like this and will it settle down or has it just been set up wrong? I can't take it over to the dealers until next week due to the bank holiday but if anyone has any thoughts, they would be greatly appreciated.
adzpz
Re: After the new shocks, car is higher at front
Post by adzpz » Fri Apr 22, 2011 5:22 pm
Probably just needs to settle where it's been up in the air, take it for a long drive and see how it looks.
Current: RS4 B7 Saloon
Previous: BMW E46 330cd - Remapped to 250bhp and BBS LM's
VW Golf MKIV GT TDI 150BHP
Peugeot 206 GTi 180
Peugeot 206 GTi
Peugeot 206 1.1 :)
sonny
Post by sonny » Fri Apr 22, 2011 5:56 pm
I remember a article on here a while back, dealer fitted SS instead of SS+ resulting in the front of the car being higher.
irvind
Post by irvind » Fri Apr 22, 2011 7:55 pm
Mine sits higher at the front too, seem to remember reading on here somewhere that this is the norm? (within reason of course!)
ArthurPE
Post by ArthurPE » Fri Apr 22, 2011 8:26 pm
what is the ride height
measure from ground to fender lip, centerline of wheel?
for the front and rear
sometimes the system is over-pressurized and pumps the front up a bit
sometimes when the system has failed, the front sags a bit, and when fixed (returned to normal height) is 'looks' high, relative to when it was broken, but is the correct height
P_G
Post by P_G » Fri Apr 22, 2011 9:02 pm
On standard suspension on my Avant the front sits higher than the rear by the gaps you mention. It is normal. And that is at 15 Bar DRC pressure verified at my last service.
Hozz
Post by Hozz » Sat Apr 23, 2011 9:04 am
I really appreciate the responses guys, thanks, it has put my mind at rest and I'll just see if it settles down a bit more after a few miles are put on them.
Pie
Post by Pie » Sat Apr 23, 2011 10:41 am
I have SS+ and the front does sit noticeably higher than the rear so nothing to worry about.
As has already been said, take it out for a spirited drive, hammer on the brakes a few times to load up the front end and it should settle.
SS+ Rear
SS+ Front
3.141
_________________________________
'14 C63 AMG Edition 507
'07 B7 RS4 +Milltek Non-Res, Non-Valved (Sold)
'10 YZF R1 + Akrapovics
Stoffle32
Post by Stoffle32 » Sat Apr 23, 2011 3:16 pm
I had the first problem when my DRC was changed, 2 weeks later I took it to the dealer, as they also only replaced the front shocks, and to my surprise they didn't pressurize the system properly and they had to replace the rear shocks as well... now the car sits pretty even, 2 fingers in the front and I can just fit 2 fingers in the back, but it is more of a squeeze... My mates RS4 is the same..
Steve_C
Post by Steve_C » Sun Apr 24, 2011 11:57 pm
P_G wrote:On standard suspension on my Avant the front sits higher than the rear by the gaps you mention. It is normal.
+1
Gone to the dark side
