My RS4 has developed a high pitched "whirring" noise when I set off slowly. If I dab the brakes the nosie stops, however, thinking it was the brakes binding I have had the calipers in bits, cleaned them up but the noise is still there.
My mechanically minded friend seems to think it could be the release bearing in the clutch...?
And help on the matter appreciated.
Hi Pitched "Whirring" When Setting Off.
- Revolution
- Trader (Expired)
Re: Hi Pitched "Whirring" When Setting Off.
Could it be power steering pump, low fluid?
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
As Revolution says, check fluid levels.
After that its down to process of elimination.
Does the noise still exist at idle & static with the clutch pedal up / down?
Does the noise exist with pedal up / down when coasting at low speed in or out of gear?
Which side does the sound appear to come from?
Get the car up on a jack and rotate that wheel by hand listening and feeling for any sort of obvious resistance (may be hard since its Quattro)
You tried drilling out the holes in the discs and cleaning out all the built up crap?
Could also be a bad earth somewhere and you're hearing it through your radio, switch off completely and try again.
3.141
_________________________________
'14 C63 AMG Edition 507
'07 B7 RS4 +Milltek Non-Res, Non-Valved (Sold)
'10 YZF R1 + Akrapovics
Users browsing this forum: Google Adsense [Bot] and 263 guests
