Engine "bogging" down under hard acceleration when shifting
richieg888
Post by richieg888 » Wed Apr 13, 2011 3:29 am
My RS4's engine "bogs" down under full throttle when shifting from 2nd -3rd or 3rd to 4th gears....
If you give a second or a little breather before shifting it does not "bog" down and shifts perfectly... Is this normal?
I have tried researching and some people say it may be a defective or dirty MAF... Some people say its the traction control "kicking-in" protecting the tranny.... I have tried turning off the traction control and it seems to work but I still have doubts since the RS4 is a high performance car... Wasn't it made to be driven hard ?
Has anyone encountered this problem? Is this a possible early signs of carbon build up? hope you guys can shed some light ...
Richie
P_G
Re: Engine "bogging" down under hard acceleration when shift
Post by P_G » Wed Apr 13, 2011 7:21 am
You have suggested the answer, it is ESP limiting tyre slip and protecting the transmission coupled with throttle / torque limiter which is apparent in 1st/ 2nd/3rd. Switch ESP off and it will improve.
Steve_C
Post by Steve_C » Wed Apr 13, 2011 9:20 am
P_G wrote:You have suggested the answer, it is ESP limiting tyre slip and protecting the transmission coupled with throttle / torque limiter which is apparent in 1st/ 2nd/3rd. Switch ESP off and it will improve.
+1, there was a thread on this a couple of weeks ago.
Gone to the dark side
richieg888
Post by richieg888 » Wed Apr 13, 2011 9:54 am
Thanks will review the thread of last week. Is it normal that when ESP is triggered that no ESP lights blink?
P_G
Post by P_G » Wed Apr 13, 2011 10:11 am
If you press the ESP button then it will flash on and off, that is stage one disabled. If you press and hold the button for 5 seconds it is permanently illuminated which is stage two off. In the scenario you are describing only when the wheels actually lose traction will you see the light flashing, the system is proactively stopping this happening which is why you probably won't see it flash on a dry road.
richieg888
Post by richieg888 » Wed Apr 13, 2011 10:23 am
P_G wrote:If you press the ESP button then it will flash on and off, that is stage one disabled. If you press and hold the button for 5 seconds it is permanently illuminated which is stage II off. In the secnario you are describing only when the wheels actually lose traction will you see the light flashing, the system is proactively stopping this happening which is why you probably won't see it flash on a dry road.
Cheers! for this :)
richieg888
Post by richieg888 » Wed Apr 13, 2011 10:28 am
Tried looking for the thread acn't seem to find it. Would you happen to remember the tittle of the thread? or sahre the link?
Chers in advance !
Steve_C
Post by Steve_C » Wed Apr 13, 2011 10:31 am
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Apr 14, 2011 9:12 am
if you are too quick back on full throttle when the clutch switch is still engaged you can get a throttle cut. You also get this with a brake switch adjusted too close and the movement of the mounting points when your are using the clutch can make the brake switch operate.
http://www.MRCtuning.com
Users browsing this forum: No registered users and 721 guests
