Bonnet position
KernowPete
Bonnet position
Post by KernowPete » Thu Mar 10, 2011 10:07 am
Hi all
I've recently noticed that my bonnet doesn't seem to be sitting quite right when shut. The side edges align perfectly with the edges of the wings, but the front edge seems to be sitting too high, and there is quiet a gap between the edge of the bonnet and the tops of the headlights and grill etc. It's a gap big enough to almost get a finger into, probably half an inch or so where the bonnet meets the front bodywork between the headlights and the grill. At the same time though, it's very securely shut and not at all loose. I'm assuming this probably isn't right? If so, what can be done?
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
Revolution
Trader (Expired)
Re: Bonnet position
Post by Revolution » Thu Mar 10, 2011 10:20 am
From my experience its quite common with cars we get in
Its the bumper thats sitting too low, you will need to loosen it and lift it up a touch.
Bt of a faff but we did it on mine and made a noticeable difference.
Glenn
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
Steve_C
Re: Bonnet position
Post by Steve_C » Thu Mar 10, 2011 10:46 am
Yes, its the bumper out of position rather than the bonnet. This was discussed on here (with photos) around Nov/Dec time IIRC.
Gone to the dark side
KernowPete
Re: Bonnet position
Post by KernowPete » Thu Mar 10, 2011 11:45 am
Cheers guys, but won't doing that put it out of alignment with the wings? Or am I being thick?
Revolution
Trader (Expired)
Re: Bonnet position
Post by Revolution » Thu Mar 10, 2011 12:03 pm
no as youre just hitching it up a little
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
sonny
Re: Bonnet position
Post by sonny » Thu Mar 10, 2011 12:29 pm
Sometimes the bumper gets put back on incorrectly and just missing the bracket, it has been known for the bracket to break due heavy handed mechanics :audibash:
As said it just adjusts using a long torx driver in the top of the bumper. You may have to re-align headlight.
ShouldveBeenAGerman
Re: Bonnet position
Post by ShouldveBeenAGerman » Thu Mar 10, 2011 12:35 pm
sonny wrote:Sometimes the bumper gets put back on incorrectly and just missing the bracket, it has been known for the bracket to break due heavy handed mechanics :audibash:
The torx undoes the locking bolt holding the adjuster tight, you then need to wind the actual black mount to the desired position and lock it off with the torx bolt again.
ShouldveBeenAGerman
Re: Bonnet position
Post by ShouldveBeenAGerman » Thu Mar 10, 2011 12:39 pm
I did mine as soon as I bought it. The bumper was sitting low and the bonnet adjusters needed a few turns. It now sits perfectly. :thumb:
neckarsulm
Re: Bonnet position
Post by neckarsulm » Thu Mar 10, 2011 10:58 pm
the slam panel/rad support panel/lock carrier can also be on incorrectly and this will cause the lamps to sit low as they are fixed to it.
lofty
Re: Bonnet position
Post by lofty » Thu Mar 10, 2011 11:19 pm
ShouldveBeenAGerman wrote:I did mine as soon as I bought it. The bumper was sitting low and the bonnet adjusters needed a few turns. It now sits perfectly. :thumb:
This really gets on my t*ts,mine looks like yours did on the top photo.Looks way better after the adjustment,is it difficult to do?
sonny
Re: Bonnet position
Post by sonny » Fri Mar 11, 2011 7:38 am
Looking a lot better.
ShouldveBeenAGerman
Re: Bonnet position
Post by ShouldveBeenAGerman » Fri Mar 11, 2011 11:44 am
lofty wrote: This really gets on my t*ts,mine looks like yours did on the top photo.Looks way better after the adjustment,is it difficult to do?
It's a bit of a pain TBH, accessing all the bolts that hold the bumper on. You don't need to completely remove it, but it's not far off to get to the winders, make the adjustment and get a snug fit.
Ice_Coffee
Re: Bonnet position
Post by Ice_Coffee » Fri Mar 11, 2011 1:59 pm
according to elsawin the correct gapping is 3.5mm on the sides and 5mm along the top (grille to bonnet)
Steve_C
Re: Bonnet position
Post by Steve_C » Fri Mar 11, 2011 2:01 pm
Ice_Coffee wrote:according to elsawin the correct gapping is 3.5mm on the sides and 5mm along the top (grille to bonnet)
Thanks, will get the tape measure out on mine as I think it might be more than that.
KernowPete
Re: Bonnet position
Post by KernowPete » Fri Mar 11, 2011 8:22 pm
Mines WAY more than that.
I've got the tools sorted and located the adjusters, is it just a case of winding them up until the bumpers in the correct position?
Users browsing this forum: Google Adsense [Bot] and 207 guests
