Rear brake caliper rewind
Noginthenog
Anyone know where I can get a rewind tool for the rear calipers? (has 3 locating lugs instead of 3)
Noginthenog
Re: Rear brake caliper rewind
D'oh!! Should read 3 locating lugs instead of 2!!!
Noginthenog
For those that need to know there is an elctronic tool required to do this as it rewinds via the same motor that winds the caliper out. Not cheap either.
Do you mean Vag-com, or is there something else?
http://wiki.ross-tech.com/wiki/index.ph ... king_Brake
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
Hi!
New member on here
Also to add;
After recent worn rear pads & disc replaced on mine: I am told that if the diagnostics is not reset correctly the low pad thickness warning does not illuminate at all
G
New member on here
Also to add;
G
Users browsing this forum: No registered users and 52 guests
