Disappointed with my rear end
goose
Post by goose » Fri Jan 21, 2011 12:13 pm
I'll have to start this minor rant with a statement in that my previous car (Mk4 R32) was extremely rigid; with upgraded springs, race front and rear arbs, front upper and lower strut braces, rear lower brace, and poly bushes throughout... So getting a large(ish) 4 door saloon was a bit of a shocker in the handling stakes.
I've experienced a combination of massive understeer when turning-in hard.. to alarming oversteer when provoked.
Having reviewed various arb offerings/set-ups (& costs), i figured the 22mm B7 RS4 Rear ARB was the most cost effective to dial-out the understeer without going to extreme for a road car...
Parts ordered, car jacked, (bolt sheared DOH!) exhaust off, imagine my surprise and subsequant disappointment when i see that it already has the RS4 Rear bar on it :oops:
I blame myself for not checking first.. but i have to say, if this set-up is (as I've read), better than stock.. then I'm not that impressed.
Unit 20 & Hotchkiss here i come.... http://www.ekmpowershop16.com/ekmps/sho ... ng-8-c.asp 8)
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
nihc
Post by nihc » Fri Jan 21, 2011 12:23 pm
Hi,
Have you checked the diameter of the RARB just to make sure. The RS4 one is 22 mm.
I wonder if someone has uprated the front ARB, as that would cancel the effect of the RS4 RARB. Only the rear ARB should be upgraded.
There is a big difference with the RS4 RARB. I do drive my S4 very hard and the understeer is just noticable in the wet now.
Regards, Chris.
goose
Post by goose » Fri Jan 21, 2011 12:30 pm
nihc wrote:Hi,
Regards, Chris.
Cheers Chris... Yep, was defo a 22mm bar already on there... measured them side-by-side and they were identical.
Previous owner must have upgraded it... i just thought it would be better i guess :roll:
goose
Current:
Past:
nihc
Post by nihc » Fri Jan 21, 2011 1:16 pm
Have you checked the front ARB? I'll get the calipers on and see what diameter the standard one is. You haven't been sold the standard S4 RARB by mistake have you?
What tyres have you got on?
I suppose it's never going to be great with a big V8 up front.
Regards, Chris.
MattS5
Post by MattS5 » Fri Jan 21, 2011 1:47 pm
And to add insult to injury, there was no need to remove the exhaust to fit the ARB, it will squeeze in there without taking it off!
xyber
Post by xyber » Fri Jan 21, 2011 1:56 pm
It'll be worth it. The Hotchkis kit transforms the handling
BlingBling
Post by BlingBling » Fri Jan 21, 2011 2:36 pm
This may sound odd. But you are probably not driving the car correctly if you are suffering from massive understeer, too quick into corners, and then alarming oversteer, probably due to lifting off mid corner to counter the understeer.
The RS4 ARB does increase lift off oversteer quite a lot. I have the RS4 ARB and it does reduce understeer dramatically compered to the stock set up. But again the driving style has to be adjusted in order ot get the best of the car.
The S4 cannot be thrown around like a R32. The driving style required is very much different.
goose
Post by goose » Fri Jan 21, 2011 3:50 pm
I've checked the front ARB, and all is fine... both old and new rear ARBs were measured with calipers, and both were RS4 22mm bars.. tyre-wise, i'm running Goodyear Eagle F1's front and rear, all x4 less than 3 months old.
goose
Current:
Past:
Scotty
Post by Scotty » Fri Jan 21, 2011 9:38 pm
BlingBling wrote:This may sound odd. But you are probably not driving the car correctly if you are suffering from massive understeer, too quick into corners, and then alarming oversteer, probably due to lifting off mid corner to counter the understeer.
Totally agree. With the big lump hanging in front of the front axle understeer is the natural state. I fitted the ARB and it helped but you certainly need to drive it in a certain fashion.
I found that slower in and feeling for th inside front wheel to be hooked up before applying more gas was the way. Getting on the gas just before the apex meant it would sling shot out. Try throwing it in faster just meant a wide drift and a very slow exit.
Oh and talking of the lift off oversteer, this is a video of me showing an RS6 owner how to play with it :
http://video.google.com/videoplay?docid ... 0518935842#
B8 A4 Avant quattro
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
xyber
Post by xyber » Fri Jan 21, 2011 10:51 pm
I found that with KWv3's, Hotchkis RS4 ARBs (rear set to soft) and Vred Sessanta's (225 profile), very little unsettles it. Great fun in the summer when the roads are warmed up!!
