Hi guys - new S4 owner
balfim
Post by balfim » Tue Jan 18, 2011 9:46 pm
Just a quick message to say hello - and ask a question or two....
First off - Hello ;)
And now the questions...
Purchased a 53 plate S4 (Manual) a couple of weeks ago (one owner 70K) - and after reading a few (bloody hundreds of posts) on here, I am pretty well educated in the ups and downs of S4 motoring!
However, got a slight issue with the gearbox and was wondering whether anyone else has had a similar experience.. Basically when selecting either 2nd or 3rd gear when going up through the gears there is a definate 'grind'. I never seem to notice anything when changing down - only up.
I had a full gearbox oil change yesterday and things improved slightly - though when I started the car today, it was a real struggle to select 1st or 2nd until the gearbox had warmed up a bit.
Anyone got any ideas? I've used the search function and cant find anythign similar.... I'm dropping it off at the dealership I purchased it from tomorrow so fingers crossed they will be able to get it mended.. (not sure they will be impressed with the MIJ CAT back I had installed on sat - but 'hey ho!!)
Any comments or advice would be greatfully recieved. I can only assume its a synchro issue - though am not sure as the issue only becomes apparant when going up through the gears and not down....
Balf
IntJetSet
Post by IntJetSet » Tue Jan 18, 2011 10:59 pm
It could be a syncro issue. the early B6 S4's suffered from this apparently and it was a fix that should/could have been done under warranty.
I don't know much about it but if you speak to Audi they will be able to tell you the full history of the work undertaken by them including all warranty work.
Noob so go easy...
Users browsing this forum: No registered users and 26 guests
