A few JHM Parts I was not aware of before
matthew.lewis2
Post by matthew.lewis2 » Tue Jan 18, 2011 9:19 am
I was browsing the www last night (I found out that my bonnet strut has failed and was researching prices), and came across a few goodies on JHM's website that I had not seen / nor seen discussed before. I thought the following may be of interest to the forum.
Upgraded rear diff mount - http://tinyurl.com/4zm8go4
Shifter linkage upgrade - http://tinyurl.com/6yywl3w
Lightweight flywheel and clutch - http://tinyurl.com/5tyc6nk
380mmm front rotor upgrade http://tinyurl.com/68w3ahk
Front upper adjustable control arms - http://tinyurl.com/6z6kuc4
Front upper adjustable control arms - http://tinyurl.com/656omhg
Silicone MAF hose - http://tinyurl.com/4z9pr3a
I was aware of the following parts before-hand but for completeness I thought I would include in this post...
Rear brake rotors - http://tinyurl.com/66e2uu8
Front brake rotors (standard diameter) - http://tinyurl.com/5tcodol
approved
RE: A few JHM Parts I was not aware of before
Post by approved » Tue Jan 18, 2011 10:01 am
those discs look cheap.
are they any good?
matthew.lewis2
Re: RE: A few JHM Parts I was not aware of before
Post by matthew.lewis2 » Tue Jan 18, 2011 10:15 am
jonathonturner wrote:those discs look cheap.
are they any good?
I have not used them (yet), but I plan to install the JHM rotors (not sure whether to go with the standard size or the upgraded 380mm rotors yet) when they next require changing. By all accounts they are very good.
The new MAF pipe was a new one on me.
Also, here http://tinyurl.com/67v5339 would seem to indicate that JHM will have an exhaust offering for the B7 RS4 in the very near future.
Ice_Coffee
RE: Re: RE: A few JHM Parts I was not aware of before
Post by Ice_Coffee » Tue Jan 18, 2011 11:38 am
Apart from additional heat dissipation, what use are the bigger discs if you do not have bigger pads to match?
aidanjaye
Post by aidanjaye » Tue Jan 18, 2011 11:46 am
Leaverage I think.....the furthur out from hub, the better the stopping power (or so).
I reckon the 380 mm look good as well. Will defo be looking when I need to renew discs.
And if you combine rotors, with pads, possibly short shift and such - the combined postage shouldn't be that bad although dread to think what customs will want>>>
matthew.lewis2
Re: RE: Re: RE: A few JHM Parts I was not aware of before
Post by matthew.lewis2 » Tue Jan 18, 2011 11:49 am
Ice_Coffee wrote:Apart from additional heat dissipation, what use are the bigger discs if you do not have bigger pads to match?
Bigger disks help because they increase the mechanical leaverage being applied. Just like using a longer lever to help lift a mass.
aidanjaye
Post by aidanjaye » Tue Jan 18, 2011 1:37 pm
and no JHM stockist in UK which is a pity.
P_G
Post by P_G » Tue Jan 18, 2011 1:52 pm
are they any good?
DannyRS4 has them on his car but still hasn't posted any pics up of them!!!!! :wink: :wink: :wink: :wink:
They are good value but FedEx / UPS is another $400 plus excise duty @ 20% so end up being slightly more then OEM front discs.
thedoluk
RE: Re: RE: Re: RE: A few JHM Parts I was not aware of befor
Post by thedoluk » Tue Jan 18, 2011 2:03 pm
I've got the shifter, MAF hose and diff mount fitted. Waiting for my current pads to wear out before I fit their disks all round went for the 380mm, also going to fit braided hoses with rbf600 fluid. So hopefully should feel an improvement.
Daytona Avant - Optics - Titanium pack - MRC 464.6ps 513Nm - H&R ARBs + Springs - Apikol Diff mount - 034 Tranny mount - JHM Shifter
xyber
Post by xyber » Tue Jan 18, 2011 3:24 pm
aidanjaye wrote:and no JHM stockist in UK which is a pity.
Satanschild is a UK dealer
adsgreen
Post by adsgreen » Tue Jan 18, 2011 3:45 pm
I do like the look of the brake discs - much prefer slotted to x-drilled.
P_G
Post by P_G » Tue Jan 18, 2011 3:58 pm
There nothing on his site to say that he sells JHM and none of their bits?
S4Player
Post by S4Player » Tue Jan 18, 2011 4:45 pm
I've got the jhm rotors and there trio short shift package which is linkages etc both parts high quality! Call doug@mrc he has a supplier for all jhm parts pg I'll post they pics up before dinner time today you have my word
S4Player
Post by S4Player » Tue Jan 18, 2011 5:07 pm
how do i add a picture?
P_G
Post by P_G » Tue Jan 18, 2011 5:10 pm
Get a free photobucket account, upload and store them there, copy the direct link under each pic and then insert each one using the IMG tab above the reply text box before and after pasting each link..
Users browsing this forum: No registered users and 105 guests
