ECU Fried. Need a new one. VEMS
2.2 I5 20v turbo - 315 bhp
wowow
Post by wowow » Mon Jan 17, 2011 3:29 pm
Anyone can tell me where I can get one ? How easy is it to install VEMS. Is it PnP ? I guess not as I have read their website and have no idea what they are selling in terms of the hardware. Pls help
wowow
RE: ECU Fried. Need a new one. VEMS
Post by wowow » Mon Jan 17, 2011 4:09 pm
If I go to someone like MRC tuning, will they give me a new ECU, or they give me a box that "connects" to the ECU. As said, I am a newbie....
darkhorse1210
Post by darkhorse1210 » Thu Jan 20, 2011 5:57 pm
Have you tried 'Superchips'?
http://www.superchips.co.uk/
I haven't tried them but they were recommended to me
VaudiGR
Post by VaudiGR » Fri Jan 21, 2011 8:40 am
vems is very easy to install. If you have any questions, let me know.
where are you located? I run VEMS ecu for about a year+ now and i can get it working for you. I am not a tuner, but i learned myself. pm me if you want.
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jan 21, 2011 3:47 pm
The trouble with VEMS is that you need to either set up everything yourself or have someone do it for you. You can't just buy one, plug it in and forget about it as far as I know :)
VaudiGR
Post by VaudiGR » Fri Jan 21, 2011 7:24 pm
sure, BUT it is so user friendly that once you have a base map all you need is time to get it properly setup. Most ECUs. will come with a base map and proper base settings for you to start. So you will spend very little time messing around with them. Its the tables that will interest you most.
Obviously you will have support from the seller (depending who that will be) you get more or less support. But as i said, vems is a sort of open community, so there is a lot of information out there that can get you a good tune and some nice/safe results. Plus, it is so straight forward to use, that any tuner can tune it for you if you need to.
wowow
Post by wowow » Wed Jan 26, 2011 1:29 pm
I live in HK and there is not enough support to make it comfortable for me to try VEMS. Fortunately, I found someone who can repair the fried part on the ECU. One of these days I will give VEMS a try after I spend some time learning it on the internet. Thanks anyway guys.
Users browsing this forum: Google [Bot] and 11 guests
