Milltek & 10mm Spacers - Before and After
Pie
Post by Pie » Mon Jan 17, 2011 12:25 am
Since they're both fairly commonly asked questions I took some before and after photos of 10mm spacers on the rear and also a video of OEM vs Milltek (Non Valved, Non Res)
Its been the first dry, sunny and (comparatively) warm day this year so took the opportunity to clear the never ending to-do list.
:arrow: Fit BMC Filter and 10mm rear spacers
:arrow: Fit LED Sidelights (Mission aborted, looked like an arsehole of a job!)
:arrow: Wash RS4 and other half's Polo
:arrow: Fit tailtidy and LED indicators to bike
Without Spacers (Pre-wash)
With 10mm Spacers (Post wash)
Standard Exhaust Vs Milltek Non-Res, Non Valved (@ Idle)
Real difference is through the gears on the road but I never got round to making that vid with the OEM exhaust.
http://www.youtube.com/watch?v=nNllAuCBIw8
And heres a bonus vid of the R1 - Cross plane crankshaft and Akrapovic exhausts :mrgreen:
http://www.youtube.com/watch?v=tR0p9HCBb50
3.141
_________________________________
'14 C63 AMG Edition 507
'07 B7 RS4 +Milltek Non-Res, Non-Valved (Sold)
'10 YZF R1 + Akrapovics
ArthurPE
RE: Milltek & 10mm Spacers - Before and After
Post by ArthurPE » Mon Jan 17, 2011 12:41 am
sounds like someone's been a busy boy :D
looks good
spacers make a big difference in the stance
get some 6 mm for the front (maybe 8's)
sonny
Post by sonny » Mon Jan 17, 2011 1:36 am
God I love the sound of these cars. Looks good fella.
RS4-Chew
Post by RS4-Chew » Mon Jan 17, 2011 3:43 pm
Looking good pie
Im after some spacers for the back - can you provide a link please?
Original wheel nuts fit ok or extended items required?
Really want to get some but unsure of rubbing / bearing hub wear etc.... :ban:
Mines a 57 saloon NON Sports Sus - 10mm rears ok - fit straight on?
thx
07/57-B7 RS4 Saloon-Sprint Blue,Tech Pack, DRL's,Bluetooth,Carbon Trim,Chrome Optics,Sunroof,open zorst flaps,FBSW,Bose,Buckets,New Boots,R8 alu oil cap,BMC panel,RS plate,Fresh plugs,10mm Rear H+R spacers courtesy of Virdee.
Also - 1970 MGBGT for Hillclimbing and Sprint racing
03/53 - MK4 Deep Blue Pearl R32 3 door (sold)
"You never hear a truer word spoken in jest"
DuncS3
Post by DuncS3 » Mon Jan 17, 2011 4:49 pm
Thanks for the video - still got to hear in the flesh i think
Pie
Post by Pie » Mon Jan 17, 2011 4:54 pm
I got mine from http://www.dpmperformance.co.uk/ and they came with 10x extended wheel bolts.
Just make sure to get the hubcentric spacers so the bolts aren’t taking all the load.
Locking wheel nuts aren’t included and the OEM ones aren’t long enough to go through the spacer so you’ll need to get longer ones from the likes of McGards.
M14 x 1.5, 35mm Lg (I think) Radius Seat.
Spacers will fit straight on with no arch fouling but just make sure to have a piece of emery or sandpaper handy to clean any rust off the hub face for a neater fit.
3.141
chrisd31
Post by chrisd31 » Mon Jan 17, 2011 5:59 pm
can they still be fitted if you have the SS+ pack on?
aidanjaye
Post by aidanjaye » Mon Jan 17, 2011 6:03 pm
Only problem you get with having spacers is most of the road crap peppers the side skirts, although I do have 275s fitted as well.
Pie
Re: RE: Milltek & 10mm Spacers - Before and After
Post by Pie » Mon Jan 17, 2011 6:19 pm
chrisd31 wrote:can they still be fitted if you have the SS+ pack on?
Yes, my car has SS+ and no problems.
I only have spacers on the rear at the moment though, still trying to decide if I should fit to the front although I believe 10mm is a bit much and you should either be looking at 3mm or 8mm depending on tyre width?
3.141
andre3k
Post by andre3k » Mon Jan 17, 2011 6:39 pm
Pie wrote:M14 x 1.5, 35mm Lg (I think) Radius Seat.
Hi mate, can I confirm it's 28032 you're on about
http://www.mcgard.com/Applications/Auto ... wvBg%3d%3d
lengster1
RE: Re: RE: Milltek & 10mm Spacers - Before and After
Post by lengster1 » Mon Jan 17, 2011 7:11 pm
3mm plain on the front is perfect imo and ok to retain standard bolts,i prefer taper bolts you have a far greater mating surface than with radius,you end up with a thin ring contact area and can dig into the taper in your wheels,only my opinion and preference though,R1 sounds good but like the RS4 much in the flesh so to speak
Pie
Post by Pie » Mon Jan 17, 2011 7:57 pm
Yeah thats the closest you'll get with the McGards range.
Audi standard bolts are 27mm long and the locking one is closer to 29mm.
Add on 10mm for your spacer and you'd be looking at a corrected range of between 37mm - 39mm.
28032 kit is 34.5mm so should fit (I say should as I have yet to order mine!)
The next one up is 28017 which is 44.5mm but I'm not sure if this will perhaps be too long and bottom out on the hub.
With OEM bolts you're capturing about 10mm-11mm worth of thread once fully tightened; with McGards 28032 you'll get 7.5mm-8mm which is still a good 5 threads of engagement (plus the 4 other replacement bolts)
3.141
ShouldveBeenAGerman
Post by ShouldveBeenAGerman » Tue Jan 18, 2011 11:16 am
Looks great Pie, any pictures from behind showing the wider stance?
Loving the R1 BTW........must resist :)
RS4-Chew
Post by RS4-Chew » Tue Jan 18, 2011 11:22 am
Just about to order some
are these the same as yours pie?
hubcentric H+R's 10mm
http://www.dpmperformance.co.uk/hr-trak ... -3538.html
(including extended pins)
appreciate your reply
also anyone got the linky to the correct locknuts for when these are fitted?
car is standard at the mo
Gracias :beerchug:
andre3k
Re: RE: Re: RE: Milltek & 10mm Spacers - Before and Afte
Post by andre3k » Tue Jan 18, 2011 12:06 pm
RS4-Chew wrote:Just about to order some
Gracias :beerchug:
I think you need Part No. 202555713 (H&R Hubcentrics DR,10mm)
Not sure about the one in the link
Users browsing this forum: No registered users and 353 guests
