Engine light and a wobble?
Afternoon,
I'm a new owner of a Phantom Black B7 saloon - very happy a month or so into ownership. The car has only 13,500 miles and is in pretty good condition. Four new Vredesteins and a proper wheel alignment this weekend has cured some slightly skittish handling. There is some more cosmetic work to be done (removal of GSM dash prep and some minor external scratch repair) then I'll post some pictures.
However (sigh...) the engine warning light started flashing while driving to work this morning. I think it was flashing then a pause (off) then flashing. Nothing obviously wrong. Just tried sitting in it in the car park. After start up the light was permanently flashing. After revving the engine to about 3k RPM the light went solid on. There is also a definite "wobble" coming from the engine at idle that I can feel through the steering wheel and driver's seat.
Before I call Camberley for the first time - any ideas?
Cross fingers it's a coilpack or something simple.
C
C
RE: Engine light and a wobble?
Coil pack...defo...mine did exactly the same...the wobble is the engine not firing on all cylinders.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Does a failed coilpack cause the check engine light to come on?
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
- 5th Gear
Re: RE: Engine light and a wobble?
Yep...wolfgang wrote:Does a failed coilpack cause the check engine light to come on?
PeteS4 wrote:Do you have a warranty?
It seems there has been quite a few new owners recently who have been having one problem or another
Trouble is...as with any car they getting no younger....some of the oldest cars are 4.5 years old now....Problems are bound to start.
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Hell yeah.wolfgang wrote:Does a failed coilpack cause the check engine light to come on?
Failed coil pack will cause a misfire on one cylinder and not only trip the engine light but also cause it to flash. This means there's a large enough misfire detected to have unburnt fuel getting into the cat (very bad) and will probably engage limp home mode where it'll disable one or more cylinders. It'll most likely flash under load when any misfire would be more noticeable.
Surprised on such a low mileage car - might be worth checking for water in the plugs.
The good news is that as the coil packs are mounted on the spark plugs it should be easy enough to change and the bulk of the cost on the parts.
Agree - coil pack. However if its under warranty get them to change them all, as sods law a few more will pack in. (I changed all 8 on my old S4 V8).adsgreen wrote:Hell yeah.wolfgang wrote:Does a failed coilpack cause the check engine light to come on?
Easy to do though, will take about 40 min max.
RE: Re: RE: Engine light and a wobble?
Not common though are they though on our cars?
Maybe it's the low mileage to blame?
Defo the low mileage. Ive been told by few technicians these cars need to be driven otherwise coil pack need replacing.
A friend of mine actually had to sell his RS4 a year ago because he wasnt driving it enough. He had to change the coil pack twice!! Crazy!
But defo its very low mileage and i would say thats the reason possibly for the coil pack going is it hasnt been driven much.
Mugello Blue - Saloon - Black Optics - H&R Spring and Rear wheel spacers - Tubi Exhaust
Re: RE: Re: RE: Engine light and a wobble?
Completed off topic...apologies, but have you any pics of your beast and some audio of the tubi. Nicely specced vehicle you have thereB7RSX wrote:Defo the low mileage. Ive been told by few technicians these cars need to be driven otherwise coil pack need replacing.
Apologies again for the hijack
RE: Re: RE: Re: RE: Engine light and a wobble?
I paid for mine when a coil pack went and it was a pretty cheap repair
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
So the AA man has been. Diagnosed a missfire in cylinder 1. Didn't have the right coilpack so we trotted to the Audi Brentford palace of dreams. Bought two spares, trekked back and replaced it. Once the fault codes were reset the ECU was no longer producing a fault code but the engine is still running one cylinder down and the engine warning light is lit.
We've given up (given no fault codes) so I'm waiting for the truck to come to recover to Camberley (not Brentford, thanks).
Hopefully it's a spark plug or something simple. I bought it in December and chose not to take out a warranty. It's possible there could be a big bill if something is really wrong. I also drove about 10 miles home (stopping and getting recovered on the elevated section of the M4 tends to cripple west London roads for about 3 hours so I chose to just get home carefully). So the cat might be screwed too...
i did read that newer cars shut off the fuel to the cylinder with dead coil pack to prevent damage.I also drove about 10 miles home (stopping and getting recovered on the elevated section of the M4 tends to cripple west London roads for about 3 hours so I chose to just get home carefully). So the cat might be screwed too...
Hope it's a plug which could also be damaged by lack of use or it could be fouled if lots of short journeys, old software map and cold weather.
Please do keep us posted and good luck.
- SKG_C63AMG
- 2nd Gear
hi there so hows things gone with ur car is there any news yet on what was the problem?Leodiensian wrote:So the AA man has been. Diagnosed a missfire in cylinder 1. Didn't have the right coilpack so we trotted to the Audi Brentford palace of dreams. Bought two spares, trekked back and replaced it. Once the fault codes were reset the ECU was no longer producing a fault code but the engine is still running one cylinder down and the engine warning light is lit.
Users browsing this forum: Google Adsense [Bot] and 147 guests
