Delayed Start on My RS4
B7RSX
Post by B7RSX » Sat Jan 08, 2011 8:59 pm
My RS4 sometimes has a delayed start.... have to wait several minutes pushing start button to get her fired up.
Two days back kept switching ignition on/off.. unlocking/unlocking doors then trying to start it up but didnt! So gave up. Then went tried yesterday and it started first time...
Battery is fine.
Its done it before aswell.... just doesnt start up have to keep trying and eventually does.
Is there a common fault with starter motor or something else im not aware of?
Mugello Blue - Saloon - Black Optics - H&R Spring and Rear wheel spacers - Tubi Exhaust
wolfgang
RE: Delayed Start on My RS4
Post by wolfgang » Sat Jan 08, 2011 9:03 pm
Do you mean that the starter turns the engine but the engine doesn't fire or that the starter itself doesn't turn when you press the START button?
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
B7RSX
Post by B7RSX » Sat Jan 08, 2011 9:17 pm
Sorry.
The starter turns the engine but the engine doesnt fire up. Can hear the fuel pump ignition clicking but doesnt fire up. Turn ignition off keep trying doesnt happen. Have to try it for several times then eventually fires up.
neckarsulm
Post by neckarsulm » Sat Jan 08, 2011 9:53 pm
VAG COM it, could be something stupid like a coolant temp sensor.
How old is yours as these aren't common yet on B7?
Ice_Coffee
Post by Ice_Coffee » Sun Jan 09, 2011 12:18 am
I'm thinking immobiliser, but that is based on experience of other vehicles not audis, I don't know how audis react if the key does not authenticate.
wolfgang
Post by wolfgang » Sun Jan 09, 2011 1:27 am
Is this on a cold start first thing in the morning? Or does this happen at every start, even if the engine is warm?
neckarsulm
Post by neckarsulm » Sun Jan 09, 2011 8:48 am
If immobiliser, on VW Group cars the engine will run for a second and the die and on 8E A4 SAFE will appear in the LCD display in the cluster
PetrolDave
Post by PetrolDave » Sun Jan 09, 2011 11:37 am
Do a VAG-COM scan on the engine ECUs, I'm wondering about cold start sensor or something like cam position sensor?
B7RSX
Post by B7RSX » Tue Jan 11, 2011 9:08 pm
Hi fellas.
Apologies about late reply. Normally happens on cold starts only... dont think its happened once its warmed up. Im thinking immobiliser too.... because i hear everything else turning clicking just not starting!
Now saying that i do need to mention ive got a tracker on the car which has Remote Immobilisation on it as a feature.. enabling me to disable the car at the click of a button (not while its in montion though) but im sure that the tracker is not causing the delayed start problem.
PetrolDave cam position sensor sounds expensive! I will get a VAGCOM scan on it soon... hopefully it nothing scary. Seems like its only mine doing it thought it might have been a common issue or something.
wolfgang
Post by wolfgang » Tue Jan 11, 2011 11:13 pm
Have you seen this thread?
http://www.rs246.com/index.php?name=PNp ... ic&t=87914
Could your problem be just a more severe case of this issue? In my case I think it's a condensation issue with the ignition electrics.
PetrolDave
Re: RE: Delayed Start on My RS4
Post by PetrolDave » Wed Jan 12, 2011 7:27 pm
B7RSX wrote:Now saying that i do need to mention ive got a tracker on the car which has Remote Immobilisation on it as a feature..
That's my number 1 suspect...
neckarsulm
RE: Re: RE: Delayed Start on My RS4
Post by neckarsulm » Wed Jan 12, 2011 7:34 pm
+1
B7RSX
Post by B7RSX » Wed Jan 12, 2011 10:33 pm
Hmmmm. I suppose id better ring Tracker company to come look at it first then take it further if its not the remote immobilisation.
Cheers for the input guys.
wolfgang
Post by wolfgang » Wed Jan 12, 2011 10:37 pm
I had another marque prior to my RS4 and there was a warning in the driver's manual about leaving the key fob too close to the car so that the transponders in the key fob were continuously trnasmitting a signal to the car and the car was 'armed' to unlock the doors. This particular model had keyless entry though and the warning said that having the key fob too close to the car could discharge the battery (this was after you locked up for the night).
B7RSX
Post by B7RSX » Wed Jan 12, 2011 11:01 pm
Right. My keys are well away from the car... hidden away at night for obvious reasons. Just confusin what it can be. But firstly need to get tracker company to get rid of the obvious suspicion about the delayed start then take it from there.
It can take longer to start if it hasnt been started for coupla days...
