Econ button light stuck on.
infrasilver
Post by infrasilver » Fri Nov 26, 2010 6:38 pm
I have had the Econ button light on for a few weeks and the air con is not blowing ice cold. I thought it might need a re-gas and I was not in a rush as I won't need it for a few months.
I decided to give it a scan today to make sure and below came up as the faults.
I cleared the faults and re scanned but they DTC's stayed.
Can anyone shed any light on what is wrong apart from the obvious and where the fault is located as I will fix them myself if I can find them.
Thanks in advance.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 Q
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
00819 - High Pressure Sensor (G65)
30-00 - Open or Short to Plus
Garage;
Audi S4 V8 2003.
Porsche 911 Targa 3.6 2001.
ZXR400.
http://www.youtube.com/watch?v=-itdmgw0mMI
Dom81
RE: Econ button light stuck on.
Post by Dom81 » Fri Nov 26, 2010 9:06 pm
Ross Tech Wiki doesn't cover the first code, but helps a bit on the second
http://wiki.ross-tech.com/wiki/index.php/00819
Strangely enough, if you search on "Defroster" rather than 00710 you get a link to fault code 00603 but the reference says 710B, so I guess they are related
http://wiki.ross-tech.com/wiki/index.ph ... ulltext=Go
2007 Daytona RS4 Avant
infrasilver
Post by infrasilver » Wed Dec 01, 2010 9:15 pm
I will get a new sensor and I'll take it in to a re-gas place and see what they think in case it does also require a re-gas.
I forgot to look on RT Wiki myself, it such a long time since I have used my VAGCOM it never crossed my mind.
Garage;
Audi S4 V8 2003.
ZXR400.
neckarsulm
Post by neckarsulm » Sun Dec 05, 2010 11:19 pm
as you already know no doubt, ECON light not turning off means there's a fault which wont allow compressor to engage.
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 40 guests
