Bilstein PSS9 Coilover kit for 8E/8H B6/B7 A4
Tankman
Post by Tankman » Wed Oct 27, 2010 3:43 pm
Suspension fitted to my previous B6 2.5 TDi Quattro Sport and removed prior to selling. Will not be fitting this to my new 3.0 TDi as I need money for new Bilsteins for the garage queen. Covered approximately 17,000 miles. Mostly fast motorway and upsetting some exotic stuff at the Ring and Spa. 9 Levels of adjustment and absolutely the best performing suspension you can get for the A4.
Looking for £900 which is about half cost new.
klauster
RE: Bilstein PSS9 Coilover kit for 8E/8H B6/B7 A4
Post by klauster » Wed Oct 27, 2010 3:48 pm
would this fit the RS4 B7?
Tankman
Post by Tankman » Wed Oct 27, 2010 4:23 pm
I believe that, although the S and RS have different suspension parameters and can accept the Bilstein G930 kit I am offering, with the S and RS models already having been lowered, they are unable to take the 30 - 60 mm front and 20 - 50mm rear adjustment that the set I have can offer. However with correct adjustment for height, camber and castor this set will fit the S and RS. You should not lower the car any more than the Bilstein prescribed 15 - 30mm on the front and 10 - 30mm on the rear. Axle loads, gas pressures and spring rates are the same.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Wed Oct 27, 2010 7:26 pm
The RS4 has a different part number, as to the one posted above
Virdee Autos ~ 07950-526592
