Anyone running 380mm MTM brakes?
2.7 V6 30v biturbo - 380 bhp
Skaala
Post by Skaala » Mon Oct 25, 2010 1:21 pm
I have just ordered some snowtires for my car with BBS CH 8,5x18 and I am planning either to run BBS CH Black 10x19 on summertires or 9,5x19 MTM wheels.
I want to change to the 380mm MTM brake kit before I go to the Nürburgring again :)
I know that BBS CH 10x19 will rub on the RS6 front brake setup (you need to grind slightly on the corners), and I am therefore wondering if anyone have experience with the MTM brakes. If the calipper is any bigger or smaller than the RS6 calipper.
I have been told that the 380mm MTM kit can fit under the stock "18 RS4 MKI wheels, but not to sure on the design of the BBS CH wheels.
thanks for any input
jimbo1234567
RE: Anyone running 380mm MTM brakes?
Post by jimbo1234567 » Thu Oct 28, 2010 7:56 pm
the mtm caliper is the same brembo item thats used on the rs6 and just uses a 7.5mm spacer to jack it out for the extra diameter disc.
Blue_Thunder
Re: RE: Anyone running 380mm MTM brakes?
Post by Blue_Thunder » Fri Oct 29, 2010 1:10 am
jimbo1234567 wrote:the mtm caliper is the same brembo item thats used on the rs6 and just uses a 7.5mm spacer to jack it out for the extra diameter disc.
Or you can get a replacement caliper carrier fabricated like I did so the wheels don't stick out further, ie: no need for the spacer underneath.
Skaala
Post by Skaala » Fri Oct 29, 2010 2:09 pm
ok, so the MTM calipper and C5 RS6 calipper is the same?
Blue_Thunder wrote:Or you can get a replacement caliper carrier fabricated like I did so the wheels don't stick out further, ie: no need for the spacer underneath.
Do you have any pics or specs?
dhali
Post by dhali » Fri Oct 29, 2010 8:52 pm
10 x19 BBS CH ET20 will fit with the RS6 caliper with 5mm spacer and minimal grinding of the caliper bar.
Karmann
Post by Karmann » Mon Nov 01, 2010 12:27 pm
No It ain't the mov'it 6pot is mov'its own billet caliper
Rs6 is a 8pot brembo
jimbo1234567
RE: Re: RE: Anyone running 380mm MTM brakes?
Post by jimbo1234567 » Tue Nov 02, 2010 4:49 pm
when did i mention movit brakes , they are a different company alltogether.
ronan
Post by ronan » Wed Nov 03, 2010 6:47 pm
edited, sorry
Karmann
Re: RE: Re: RE: Anyone running 380mm MTM brakes?
Post by Karmann » Thu Nov 04, 2010 2:46 pm
jimbo1234567 wrote:when did i mention movit brakes , they are a different company alltogether.
Sorry read that completely wrong
juice
RE: Re: RE: Re: RE: Anyone running 380mm MTM brakes?
Post by juice » Tue Dec 07, 2010 12:50 am
skaala did you sort this problem?
im looking to fit 380mm discs on my b7 rs4 brembos under my oem 18inch wheels.
might need a 10mm spacer tho.
post up your pics if possible.
Avus B5 RS4, Miltek down pipes/No cats/Miltek Cat-back, Wagner uprated SMIC's, short shifter, B7 brakes, Phaeton brake ducts, H&R ARB's, H&R Coilovers, AWE DTS, MRC custom Remap + water meth injection = BIG GRIN on my face with poo in my passengers pants
**Now with a Carbon roof**
'Build the best and the rest will follow'
kiwi_rs4
Post by kiwi_rs4 » Tue Dec 07, 2010 8:42 am
dhali wrote:10 x19 BBS CH ET20 will fit with the RS6 caliper with 5mm spacer and minimal grinding of the caliper bar.
Do you mind sharing how you got those wheels in 5x112? I love love those wheels with the deep concave but I thought they were only made in BMW fitment.
Skaala
Post by Skaala » Tue Dec 07, 2010 8:50 am
They are originally only for BMW, but several companies rebuild them to 5x112. One company is this company is Sweden. http://www.intera-sverige.se
I think they charge about 25.000,- SEK (Swedish Kronor) for a set of 4 wheels finished with 5x112
These wheels are from this shop:http://www.flickr.com/photos/ekkoj/sets ... 701023261/
Skaala
Re: RE: Re: RE: Re: RE: Anyone running 380mm MTM brakes?
Post by Skaala » Tue Dec 07, 2010 8:53 am
juice wrote:skaala did you sort this problem?
No, sadly not yet. I have heard from one side that the OEM RS4 "18 wheels do fot, and from someone else that there is no hope at all. Some say minimum "19 with a design that allows for big brakes ex. Sportec or MTM Bimoto.
I think I will go for the 365mm B7 RS4/RS6 setup for now. If this proves to be sufficient on the Nordschleife I will stay with it, or else I will get bigger wheels and go for the 380mm setup :)
kiwi_rs4
Post by kiwi_rs4 » Wed Dec 08, 2010 9:45 am
Skaala, sorry for the thread drift but do you mind telling me how the car rides and handles on those 19x10 wheels of yours? Is it worse than the stock wheels or about the same? They are slightly lighter I think so that should be a plus. Also what tyre size do you run?
Skaala
Post by Skaala » Wed Dec 08, 2010 11:27 am
kiwi_rs4 wrote:Skaala, sorry for the thread drift but do you mind telling me how the car rides and handles on those 19x10 wheels of yours? Is it worse than the stock wheels or about the same? They are slightly lighter I think so that should be a plus. Also what tyre size do you run?
I havent bought them yet, but normally I think people run 265/35/19 on stock suspention with these 10x19 wheels. Some have also managed to fit 275/35/19 but not sure if that is with stock suspention or not.
