Bluetooth not working....
Maximo
Post by Maximo » Sat Oct 23, 2010 10:29 pm
I have recently fitted a bluetooth module to my RNS-E. The install seemed to be quite straight forward. The problem I'm having is that although I can see the telephone options my phone hardly ever connects. Every now and then it does make a connection and functions fine but I can't find a pattern why.
Also should I be able to see the RNS-E in VAGCOM?
Ideas anyone?
craigyb
RE: Bluetooth not working....
Post by craigyb » Sun Oct 24, 2010 11:20 am
If you cannot see the RNS-E in vag com then your K-line is missing.
Maximo
Post by Maximo » Sun Oct 24, 2010 7:20 pm
Thanks for your help.
OK, so which wire would that be then? For information the car's a 2003 RS6.
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
PetrolDave
Post by PetrolDave » Sun Oct 24, 2010 7:28 pm
The pinout is on the paper label on the top of the RNS-E.
Maximo
Post by Maximo » Sun Oct 24, 2010 10:35 pm
Yes I know, I was after the wire in the harness. All of the connectors look to be in place.
Wants to colour code of the wire that goes into the k line on the rns-e?
Maximo
Post by Maximo » Thu Oct 28, 2010 12:06 am
Anyone know the colour of the K Line wire and where does is connect into the harness. I can see where it plugs into the RNS-E so I just need to know which wire to connect.
PetrolDave
Post by PetrolDave » Sat Oct 30, 2010 3:48 pm
Don't rely on wire colours, they can change from model year to model year.
craigyb
Post by craigyb » Sat Oct 30, 2010 9:22 pm
The k-line has always been green with a blue stripe in the A6/A4 old A3 etc. It's never changed. I know some colours do change from model to model but in general they stay the same in the build of the car for the type of connection.
Maximo
Post by Maximo » Wed Nov 03, 2010 1:29 am
OK sorted the K-Line so can see the RNS-E and the Bluetooth Module in VAGCOM. I'm getting 02005 – Coding Pin, 004 – No Signal/Communication as a fault code for the RNS-E. Found this on the Ross-Tech wiki, "When found in Radio/Navigation System RNS-E, Check Coding for Sound System, Check Wiring/Connectors (Connector B Pin 7 not wired)". There's nothing connected to the BOSE pin, so what coding do I need to set? My current coding is 0519313.
Return to “Electrical”
