4 wheel drive, can i change the split?
mattysupra
Post by mattysupra » Thu Oct 07, 2010 11:30 pm
is there anyway of changing the split on a rs4? does the transfer box work by clutches and a pump or is it solid fixed?
what is the split ratio by the way ?
adsgreen
RE: 4 wheel drive, can i change the split?
Post by adsgreen » Fri Oct 08, 2010 7:19 am
I think the ratio is 60/40 rear bias.
The centre differential is a torsen ATB with 4:1 ratio so theory can go to a 80/20 split depending on traction conditions.
It's mechanical so no reason you couldn't change to a different unit with different settings. Also you can get differential adjuster oil which changes the characteristics slightly too although I think this is more for plate type differentials.
Users browsing this forum: No registered users and 380 guests
