g62
2.7 V6 30v biturbo - 380 bhp
chiefmechanic
g62
Post by chiefmechanic » Tue Sep 28, 2010 10:18 pm
Hi, Can onyone tell me where the coolant temperature sender is located on the engine. This is the only fault showing when i use the vagcom. Are there any diagrams in the public domain that show where all the engine sensors are located. Thanks, Brian
neckarsulm
RE: g62
Post by neckarsulm » Wed Sep 29, 2010 8:37 am
see link below, it's easy to spot I think, look for the plug, remove it and you should see a 4 pin sensor, early ones were black, later ones green.
If you aren't sure unplug and see if VAG COM logs a fault with coolant temp sensor after clearing any exisiting faults.
Make sure you remember the orientation of the clip and make sure the old o ring comes out and ideally replace it.
Do it with cold engine to minimise coolant loss and danger
http://www.rs246.com/index.php?name=PNp ... emp+sensor
chiefmechanic
G62
Post by chiefmechanic » Wed Sep 29, 2010 3:27 pm
Thanks for that. Brian :D
