Wanted: Secondary Air Pump for B5 RS4
Contigo
Post by Contigo » Thu Sep 16, 2010 4:04 pm
Anyone got one of these going? Mine has started whining on cold start and I need it fixing before it goes.
I was tempted to remove it from the car altogether BUT I believe it can throw a CEL. Anyone know for sure if it does or not?
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
dace
RE: Wanted: Secondary Air Pump for B5 RS4
Post by dace » Thu Sep 16, 2010 4:35 pm
Just had mine removed and re-coded. I would do the same If I were you.
dace
Re: Wanted: Secondary Air Pump for B5 RS4
Post by dace » Thu Sep 16, 2010 4:40 pm
Contigo wrote:I was tempted to remove it from the car altogether BUT I believe it can throw a CEL. Anyone know for sure if it does or not?
Forgot to mention the ecu will need re-coding if removed.
Contigo
RE: Re: Wanted: Secondary Air Pump for B5 RS4
Post by Contigo » Thu Sep 16, 2010 5:15 pm
Honestly mate not got time to go up to MRC or suchlike. I might just do this
http://uk-mkivs.net/forums/t/141240.aspx
2006 BMW M6 - GONE
dace
Post by dace » Thu Sep 16, 2010 5:31 pm
I thyink you will find it is in a different position on the B5.
Contigo
Post by Contigo » Thu Sep 16, 2010 5:39 pm
yes but the bodge should work right?
2006 BMW M6 - GONE
stunew
Post by stunew » Thu Sep 16, 2010 10:57 pm
i did this repair to the wifes MK4 GTI turbo, removed the pump, drilled out the rivets, split the casings, cleaned, lubricated the o ring with grease and reassembled with new bolts and nuts. been good for over 2 years now!
