Hi RS246,
I wonder if I can draw on your knowledge base pool, so help is what I need.
I am upgrading my wife's B5 RS4 with new B7 calipers and discs at the front and B5 Clubsport drilled discs at the rear.
Can anyone advise me on braded hoses and the bleeding procedure.
I need to understand things like what type of hoses I need for this set up front and rear etc.
Thanks in advance.
Peter T.
RS4 Braded Brake Hoses??
Re: RS4 Braded Brake Hoses??
PM Sonny,
I think he has braided on his B7.
Apologies if not.
Apologies if not.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Goodridge or HELL braided hoses are most commonly used. You would need B7 hoses for the front and B5 for the rears I guess unless you have the B7 set up on the rears as well? Only problem is that they usually come as front / rear kits unlkess you contact Goodridge directly and they will fabricate one offs so long you supply them OEM hoses as a template.
Bleeding proceedure you should really use a machine so take it to an Audi stealer or independent which plugs into the ABS controller as well but IIRC can be done manually. I had my Goodridge hoses fitted by Audi, they just don't warranty / guarantee the work.
Yep got mine from Good ridge and Audi fitted mine too. Strange as they are not listed on there web page. I ordered them from Brakesforyou.
